what bolts below i.a.c?
Old Aug 25, 2011 | 06:10 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i have two threaded holes right below my iac. does anyone know whats supposed to be there?
Old Aug 25, 2011 | 05:32 PM
sch151's Avatar
Re: what bolts below i.a.c?
I'm no expert and new to TPI but I think you have two possibilities; Two #8 (metric) holes, one on top of the other, would be for the fuel line mount. Two larger holes, one on top of the other, would be for the IAT fitting (water temp.) and one would be for the fan temp. switch depending on the year of the car. Also, one of those larger holes could be used for the heater hose outlet.
Old Aug 25, 2011 | 07:26 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well i know it isnt the fuel line or for a temp switch.
Old Aug 26, 2011 | 08:54 AM
sch151's Avatar
Well you never siad exactly where the two holes were and I assumed you meant the ones in the lower intake directly below the IAC (housing). Anyway I mispoke earlier on the two #8 holes ...I think they are #6. Exactly where are the holes?
Old Aug 26, 2011 | 12:13 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
directly under iac. they are vertical bout 2in. apart.
Old Aug 26, 2011 | 04:23 PM
sch151's Avatar
Are they in the lower Intake...left of the water outlet?
What is the diameter of the holes?
Old Aug 27, 2011 | 02:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Mount for Corvette fuel rails that come in on pass side
Old Aug 27, 2011 | 07:28 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well then sch151 i stand corrected.i will just put bolts in them and forget about it. ty vetteoz.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
