Is the TBI ECU compatible with TPI
Old Aug 25, 2011 | 05:56 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
I was looking at the technical articles because I will be converting my 89 Trans Am that was originally a 305TBI to a 305 TPI, and the ECM interchange thread says all I need is a different PROM, is this right? Thanks in advance guys
Old Aug 25, 2011 | 11:44 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: Is the TBI ECU compatible with TPI
nada, need whole computer. im sure you could write a chip for that but thats not my forte...
Old Aug 27, 2011 | 01:03 PM
ok, figured I would need the tpi ecu, but had to check first
Old Sep 2, 2011 | 02:06 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
1227165 ecm for maf tpi and 1227730 for speed density. I have a hypertech for sale for the maf setup pm me if your intrested
Old Sep 2, 2011 | 10:25 AM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
You should read the repinning TBI to TPI thread in the engine swap section. It tells how to use your existing harness with the SD TPI (7730 ECM).
I just did this swap. Not too bad.
Old Sep 2, 2011 | 10:52 PM
really? I might have to look into it, because I just got the TPI harness and ECU, but its from an 87, and I cant seem to find any write ups on a TBI to MAF TPI swap
Old Sep 2, 2011 | 11:52 PM
Car: 91 formula ws6
Transmission: 4l60E
change one wires location. took me all of 5 mins to do.
i would have preferred to go map btw but seeing as i {like most people in America} am broke therefore i made work what i had. i am saving up for the 411 conversion because i like the newer computer systems and reliability....
Old Sep 4, 2011 | 02:08 PM
so was the bulkhead connector the same? I have both diagrams for the ECM connectors, but neither Alldata nor Mitchell had a bulkhead connector diagram
Old Sep 4, 2011 | 02:30 PM
Engine: Lb9
Transmission: M20
the connecter opening on body cutout on the driver's side under the passenger fender is the same shape for tbi and tpi
Old Sep 4, 2011 | 09:29 PM
Car: 91 formula ws6
Transmission: 4l60E
the connectors are the same but a few wires have to be swapped around. like i said fairly simple. if you go in the ltx/lsx swap section just compare the harness pinouts. i used an 89 camaro harness in my 91 bird. some stuff had to be moved. wires added/ shortened.
a member named pocket wrote up just about every article i used. also i used basics from austinthirdgen.com
Old Sep 5, 2011 | 10:25 AM
ok cool, thanks
Old Oct 6, 2011 | 10:30 PM
legend71's Avatar
Car: 97 SLP SS, 91 RS, 91 GTA, 92 JY FF
Engine: LT1, VRE 383 LT1, L98, LB9
Transmission: 4L60E, Astro T-5, A4, A4
Axle/Gears: 3.42, 3.70 9Bolt, 3.23, 2.73
I am doing a similar swap, a 1991 RS that i purchased with a poorly swapped in 350 (no updated injectors or ECU/PROM). I have all for the MAF tpi conversion but the ECU/PROM and fuel pump. Is it easier to modify the existing TBI harness, or the TPI harness.
Old Oct 9, 2011 | 03:11 PM
Car: 91 formula ws6
Transmission: 4l60E
if you find the proper ecm/ prom for the engine?: maf. you need to know what the donor harness is from tho. the birds and camaro do have differences. i put a camaro harness in my bird so i had to add stuff from the tbi harness namely the vss wiring. the fan wiring is in a different location. i had to move that wire from the fuse box to the ecm harness. i myself dont have the 9th injector so i used an existing wiring. the crank wire goes from the fuse box to the ecm plug c207. i just moved the location in the connectors for it. not hard. it sounds like alot of work but its not if you have the printouts of all the harnesses and look at the different locations. i highlighted what needed to be changed with the appropriate pins to swap. look for the c100 and c207 connector pinouts for the 2 harness types.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
Sanjay
Aug 12, 2015 03:41 PM
