Need help!!
Old Sep 2, 2011 | 03:39 PM
egacam5106's Avatar
Need help!!
I have a 91 Camaro Z28 TPI I made some upgrades to the engine. At idle and when driving normal runs good. The problem im having is when i give it full throttle it red lines and doesnt down shift and alot of black smoke pours out the exhaust. The transmission worked fine before i made the mods, so i went to a local performance shop. they told me i might need a custom made chip for the aftermarket parts and mods i made to the engine. Has anyone ever ran into this problem or knows anything on this. If u do help me please!
Old Sep 2, 2011 | 03:45 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Need help!!
what mods?
Old Sep 2, 2011 | 03:53 PM
egacam5106's Avatar
Re: Need help!!
Bored 40 over, heads, roller rockers, headers, ported the intake manifold alittle bit and also made the ports in the intake bigger, 8mm wires with accel header spark plugs and an adjustable fuel regulator
Old Sep 2, 2011 | 05:01 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Need help!!
black smoke is usually a bad cts. still need a custom chip burned to take advantage of mods
Old Sep 2, 2011 | 05:40 PM
egacam5106's Avatar
Re: Need help!!
Who do u use or recommend to get the chip from?
Old Sep 2, 2011 | 05:57 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Need help!!
pcmforless or you can try Harris performance.
Old Sep 2, 2011 | 06:08 PM
egacam5106's Avatar
Re: Need help!!
Awesome, man I appreciate all the help. Let me get the chip and give a try and see what she does
Old Sep 2, 2011 | 10:28 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Need help!!
you will have to send your chip to them.
