Did intake gaskets, now I've got REAL problems!
Old Sep 18, 2011 | 05:18 PM
87camaroPOS's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
I've got an 87 IROC 5.7l TPI I just did the intake manifold gaskets on. Now the car fires right up on the first crank but it runs like s***, and I can hear a sound like I've got a massive vacuum leak but I can't find it! Besides the 4 or 5 outlets on the plenum and the pcv fitting on the manifold where could the vacuum be coming from?
Also what do you guys have your timing set to?
Old Sep 18, 2011 | 05:58 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Did intake gaskets, now I've got REAL problems!
I would go back over every hose and the plenum again. Just move slowly. Another trick you could try is spraying some soapy water along the plenum. Any air leaks will show up as bubbles. Worth a shot.
Old Sep 18, 2011 | 11:25 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
You could also spray starting fluid or carb cleaner over and around the plenum and runners, to locate a vacuum leak. The rpms will increase noticeably if you spray over a vacuum leak. Probably the plenum or runner gaskets are leaking.
Check the cold start injector. I accidentally installed mine at some funny angle, tweaked the mounting bracket, and caused a huge vacuum leak.
Hope this helps.
Old Sep 19, 2011 | 07:53 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
oops
1992 Trans Am
May 10, 2023 07:19 PM
Reborn756
Sep 4, 2015 03:42 AM
mustangman65_79
Aug 8, 2015 12:07 PM
