L98 rebuild. first time removing and rebuilding an engine outside of school
Old Oct 11, 2011 | 07:15 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
so i'm pulling the engine on my gta. leaks like a *****, and the starter or something went out on it and i need to remove the exhaust anyway, also want to clean up some of the bad wiring. and this will be my first engine pull on this car.
what are some tips you people have? what to watch out for? do i need to pull the engine and trans together, or can i leave the trans in? i'm removing the heads too, anything i have to watch out there too? will i need to retime the engine once it's put back together?
all the advice will be much appreciated. thanks!
Old Oct 11, 2011 | 08:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: L98 rebuild. first time removing and rebuilding an engine outside of school
Try to keep your question to one thread in one forum of the site
Take it out the bottom, everything still attached
The usual suspects when removing an engine
Whatever you prefer, but together is easiest
Dont forget to clean the bolt holes out. Not a bad idea for the heads to hit the machine shop for a valve job
Yes
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
3rdgenparts
Aug 8, 2015 07:09 PM
