time for the build any one wanna follow?
Old Feb 2, 2012 | 06:19 PM
  #101
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: time for the build any one wanna follow?
Standard motors SK24, acdelco 217-440, gm 17111696 or you can use the feed and return ones 22514722 fuel feed -- 22516256 fuel ret.
Old Feb 3, 2012 | 09:10 PM
  #102
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
thanks man for the info i got this in a pm u sent me but how do u find the par numbers so quickly? do you keep a book handy?
Yes to explain my dilema.
its a bug in the electrical sensor.
ecm connects to the inline fuse, fuel relay, oil/fuel switch and to pump.
so heres the deal the connector in the back(infront of the tank) is gettin no power to it.
heres wat i check inline fuse - good
power to relay -good
power to pump from ecm? none
primed it and pump turned on.
so what is the one thing that i didnt check?? You geussed it the oil/fuel switch
been to busy at work will check it another day.
here is the strange part one night ecm was sendin power to pump then the next morning it wasnt???? this puzzles me . . .
the sensor is at autozone 38 bucks was thinking from tbi to tpi was a different sensor but found out no its not a different sensor
Old Feb 13, 2012 | 08:50 PM
  #103
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
any progress with the car?
Old Feb 14, 2012 | 08:23 PM
  #104
dabird07's Avatar
Car: 92 firebird
yes she is running!
sry for delays!
All i have to do is set timing tighten up lash and figure out why the speedometers not work
(i believe vss sensors bad)
what did yall find was the best timing set?
imm going to set it stock (what the book calls for)
also going to have to get a new turn signal relay i turn the turn signal on she doesnt blink just lights up.
and with lights on the left arrow on the dash stay on? ill figure it out
Right now my car idles around six hundred rpms when warm on how i got the timing set by ear and the rpm gAge. Too low (i believe so) tommorow will be the time for a timing light
my sis made a video of when it was first crankewd with just headers and a high *** timing lol post soon.
Old Feb 16, 2012 | 09:47 AM
  #105
Engine: Lb9
Transmission: M20
dabird07 , As far as the vss and buffer goes you first need to identify what vss you are using since you swapped from the t5 to a 700r4. If the wiring harness pocket sent you plugged in to the vss than it is a 4k ppm vss. When I sold you the ecm and gave you a modified v6 memcal and reprogramed the eprom I had also setup the eprom for a automatic trans so if you ever swapped transmission you would have tcc function. I had set it up for a optical vss signal assuming you were keeping the t5 and and speed buffer pin F and told you to run the ecm pin C6. If you are using the 4kvss in the transmission now Than I would have those go directly to the ecm pins B9 and B10 and use pin B11 to goto you Ip a light green wire coming out of the speed buffer pin c. If you wire it this way I will need to reprogram the eprom or you will need to buy a moates g1 and I can reprogram a eprom for you to work with magnetic vss for tcc lockup / fan speed turn off iac control.
Old Feb 17, 2012 | 08:48 AM
  #106
dabird07's Avatar
Car: 92 firebird
my trans is a automatic i never mentioned a t5???
so i will need to reprogram thee chip then. .
Old Feb 17, 2012 | 09:14 AM
  #107
dabird07's Avatar
Car: 92 firebird
tune i sent you a pm also i was thinking of clipping the wire that goes to the buffer from 207 and spliceing the c wire to it cause the speed sensor is wired to the ecm how pocket made it for me just like anmy other tpi send me a respond to my pm if you would
Old Mar 22, 2012 | 03:42 PM
  #108
dabird07's Avatar
Car: 92 firebird
been a while so here the updates!!
problems
problem and
more
problems.
o rings ripped for feul pressure regulator so i found a pack from autozone three bucks beets summits $20 version
autozone 800-9211 for the o rings (this should save headaches)
Alternator goes bad
ecm starts throwing codes.
fixed it ereased them then more codes
codes that did not make since 99???
so with that being said ecm was fried due to alternator going bad.
got a new ecm from tunedperformance (THANKS!)
then driving to my ladys house and car ran great picked her up she cut out!!!!
weird would start then die then start again. thankfully we made it across a higfhway to a gas station .. .
callerd my buddys rollback and took it home.
the next day crunk just fine! changed the filter drove it did fine gave it some wot drovew some more then right befor a storm hit she breaks down.
aft5er six tries of starting then driving, then shuting off followed by lots of patience to make it home i was well home. ??
So been talking searching and all, Heres things i did not know about walbros or the stock wire is to small and will have to get a thicker gauge wire to get voltage. .. .
and didnt know ignition coils could over heat and shut ure car off!
(learn the hard way,i know i said that before. . . .)
so goit me a fuel pressure gauge and going to buy a ignition coil and throw a hotwire for the feul pump to the alternator i hope this works lol
or maybe the car just wants a lsX in it. . . .
i will keep everyone posted
now since i found a hobby i cant afford !
Old Apr 2, 2012 | 01:53 AM
  #109
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
ha wats new, figure out andy bugs? any updates?
Old Apr 2, 2012 | 11:47 PM
  #110
dabird07's Avatar
Car: 92 firebird
Well updates yeah theres some good and some bad!
installed the hotwire kit that my buddy help me make (gave me the instructions)
involves a 8 gauge wire a relay for the feul pump
splice the 8 g wire to the relay relay to pump and ground,cant rember the connections an all .
Installed a new coil and she ran fine!
then later on a 3.42 posi rear end with disk brakes love it waiting to get my irocs some new rubber!!
Gotta figure out wat speed sensor for my speedo to read right.
looking into that now!
drove the car home from seeing my lady at college, a good 20 minute drive, got home threw on the work codes and then started the car, took a lil bit to get feul to the motor. she started and sounded terrible like before the hot wire kit was installed. then the loud whining and the car cut off.
so my conclusion is a terrible bad chinese knock off walbro that needs to get out of my tank. .. .
to be continued. . . . .
unfortunately dammit
Old Apr 2, 2012 | 11:49 PM
  #111
dabird07's Avatar
Car: 92 firebird
Re: time for the "no luck" build any one wanna follow?
lol had to change the tittle
Old May 26, 2012 | 01:29 AM
  #112
dabird07's Avatar
Car: 92 firebird
If it isnt one thing its another.. . .
TERRIBLE news
or
good news?
Good
  1. New fuel pump
  2. 3.42 posi
  3. disk brakes
  4. fixed radio
bought hood extra light and ground effect!
Bad
Simpl put i wrecked the car... dumb actions that lead to one great conclusion.
Time for the next car!!
And ofcourse its going to be a thirdgen!
Gotta stick with pontiacs !
(even though my friend showed me his new s2000 and i was leanin to go imports 91-95 mr2 that is)
Since this was my first car and all.......
That being said will more than likely be selling the car !
all the stufff i want is gonna be kept like for example
rear end , tpi setup , heads and intake.
Rest is parting out will post a add in the classifieds soon. . .
till then im hopefully gonna be test driving a new car!!
Old May 26, 2012 | 01:39 AM
  #113
Engine: Lb9
Transmission: M20
Sorry too hear the news , if it was someone elses fault I'd say give em da bird !
Old May 26, 2012 | 01:47 AM
  #114
dabird07's Avatar
Car: 92 firebird
hahahah no it was my fault for the damage both property and to the car. hahaa
Old May 29, 2012 | 10:54 PM
  #115
dabird07's Avatar
Car: 92 firebird
To keep or not to keep?
One still debates
Will have a build threAD in
the
+he b¤dy §ection
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
jharrison5
Aug 19, 2015 05:53 PM
