time for the build any one wanna follow?
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
First ever build!!!!!!
hey to all i have a 92 firebird tbi ran great fast car for a tbi now i just want a lil more
so decided to go witha tpi!!
im doing this to learn mainly with great reward of power at the end
goal to get around 250 rwhp
and around 300 or up rwt
any suggestions or facts greatly appreciated
its all a budget build and wanting to keep it under 2k
now for the parts list
87 tpi setup
with ecm
lt1 cam
91 tpi heads
cold air intake
tuning kit
nice valve covers
possible rocker arms and springs
ofcourse feul pump and lines
probably just use a stock feul pump
although the one from hawks third gen looks promising (100 dollar difference)
possible 22 Ibs injectors or bosh 3 (iff i spelled them right)(reason for this idk if stock injectors would hold lt1 if it be robbing me or wat not)
and a used 92 drum brake posi rear end 3.42 or 3.73
i did the math if everything go smooth around 1500 (the only thing i didnt check was fuel lines)
(hooker headers also!!!)
if any one sees anything wrong with this setup let me kno!
(mainly head fittings)
Parts i have in possesion and or shipping
lt1 cam
headers
tpi unit
spark plugs and wires (possible amazon sent me wrong kind got them with a gift card)
duralast double timin chain and cover
rest is on the list
this all started with a me wanting to change the cam shaft and id figure with all this off hey why not convert seemed smart right!
all this will be done with me working my job then coming home and buildin then working then building the maybe sleep
get pics soon!
any feedback?
87 tpi setup
with ecm
lt1 cam
91 tpi heads
cold air intake
tuning kit
nice valve covers
lt1 cam
headers
tpi unit
rest is on the list
get pics soon!
any feedback?
Car: 92 firebird
Re: time for the build any one wanna follow?
if every one looks around the forum u will see my threads regarding question even though most of them are stupid
well if every one looks around yall will see the post i have for this build probly caused abunch of headaches
it started with the body parts fan etc
then the raditior
water pump and all that good stuff
up next the intake and all the feul lines with some struggle (lol distributor and broke rotor butt lol long story) push rods lifter rocker arms
followed by the cam after breakin a star wrench lol never use cheap tools had to drillher out and the bolt popped out with ease
then i followed by taking of the wirre harness
Did any one else had to disconnect them from lights????????? from head lights and blinkers
got the majority off the wire harness of came to stump with the ground bolt on the passenger side.. . .
now then off to these "great flowing" manifolds
driver side was a snap the passenger side different story
im stuck on the last bolt closest to the firewall and air tube bolts are stripped making me resort to cutting them. .
and this is where im at now!!! not much done but all i have is a rachet set open end wrenches and some screw drivers lol (basic at home tools)
so far the funnest thing i have done in a while
now once my parts get here i will have more to come!!!!!!!!!
then the raditior
Car: 92 firebird
got home from work today and finally got the passenger exhaust manifold off
had to remove some stuff to get to it though
also find out the split between engine harness and light harness was about to connect them but ended up raining!!!
so thus concluded today
hopefully by the time im 20 she will run! :P
also like i said lt1 cam more n likely going with that walbro from hawks
and possibly in the future better injectors
but was wondering if anyone knows of a good aftermarket cam for a 305???
thanks just curious all the ones i find have wild duration let me know
ps found out my tpi setup comes in the mail this weekend!!! going to get her and polish her up!!!!!
post more as time comes around dang rain
) post more as time comes around dang rain
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Car: 92 firebird
nice stupid question hyrdaulic ropller tappet can it be used with roller lifters?
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Car: 92 firebird
lol
OK got my digital caliper in and measured my cams
wish i know i didnt do something right. . . . . . because lifts didnt seem to be right
lt1 510
and stock
440
i subtracted the base and lobes then times by 1.5 and this is wat i get!!
i had to do something wrong
lt1 510
and stock
440
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
GOOD LUCK WITH THE BUILD
got one of similar but mines 92 camaro to TPI
Car: 92 firebird
thanks man!!!!!!! so far so good with everything the only thing stumpin me is the cam issue
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Whats the part ## ? Should be on the shaft where the fuel pump loboe would normally be.
Car: 92 firebird
its a long numbet this should be right
c 17 242 gmpt bc17 mpt bc
117
its either bc17 or 117 but thats it let me kno
cam has a 480 lift cant rember the other lift believe 440 - 480 all i know is should be improve hp and torque greatly
117
Car: 92 firebird
so after finding specs on my lt1 cam very happy with what i bought now i wonder if those lt1 springs work for my tpi heads i just bought
and found specs on my heads
compared to lo3 heads
courtesy from this thread
https://www.thirdgen.org/forums/tbi/...-headflow.html
305 heads, 1.84"/1.50"
187 iron LO3 head: 165 intake; 140 exh (Fast355)
081 iron head: 195 intake; 110 exh (ME Leigh)
from thaT THREAD
WAS wondering about the exhaust flow and be a good gain to to port the 081 heads to 140 exhaust for my setup??
depending how much it is. . . .
any one recomend some rocker arms was looking at jegs rocker arms they say to hhave a good gain in hp
http://www.jegs.com/i/JEGS-Performan...20100/10002/-1
with lt1 springs
and possibly after market intake manifold or port mine need to call some shops and ask for a pricing. . . .
like i said goal is to have 300 rwhp
and 300+ rwt
probably only see 250 rwt
after taxes decide to do some good transmission work
from thaT THREAD
with lt1 springs
and 300+ rwt
Car: 92 firebird
wooo wee!''
this build keeps gettin better and better thanks to all who is helping
with this board i have basically a limetless access to parts hahhaha
so found everything i need for the feul inectors pump sending unit everything
and found a nice rear end from fellow member if right price could have ls1 brakes!!!
so the heads are in the shop getting tanked then seeing at i can do for port n polish probbably just get the exhaust to match up with the hooker headers on the heads
good news no wires or ecm in car!!
pulled them out before being late for work hehe
engine bay is looking good number on my ecm
i pulled 1228746
followed by these
86axkt k112630043
geussing stock numbers for tbi ecm
by next week i should have every thin minus
a rear end and harness
should have her running by the end of the month mid december if everything goes good!!!!
once again thanks to all members who is helpin excellent forum with excellent helpful members!!!! who ever created this forum deserve a medal or better yet a twin turbod ls1 motor for there thirdgen hahahhaah
i pulled 1228746
followed by these
86axkt k112630043
Car: 92 firebird
no more building lately waiting for more parts but did go pick up my heads from the machine shop and they are a beauty
3 angle valve job
resurfaced
hot tank and new springs all uinder 150!!!!
3 angle valve job
resurfaced
Car: '97 GTP
Engine: 385 sbc, 3.8 Supercharged L67 V6
Looking good so far !
A ported TPI setup would really help!
Check it out......
http://www.youtube.com/user/3859c1?feature=mhee
Check it out......
Car: 92 firebird
thanks man and fast grand prix!!!
and i heard these bases set u back never heard how much though
how much power gain did u see/notice
and one step closer all i have to get is a fpr and gaskets and bolts and i will be on my way!! plus some tools!
then ill get her back together!!!
then after engines together off to the reaR!!!!!!
aLREADY HAVE THE PUMP AND SENDING UNIT( HOPEFULLY HEHE)
JUST LOOOKIN AROUND FOR SOME GEARS!!!
then she will be drivable!!!
so far everything under 1000
fantastic build love it just minor things for a 305
Car: '97 GTP
25-30 hp on a stock engine. More on a modified one.
I can port your base manifold for 250 plus shipping. There's alot of time involved and when finished it'll flow like crazy! Plus the price is much more reasonable than an aftermarket base.
Car: 92 firebird
Car: '97 GTP
Car: 92 firebird
to this forum
great place of info to have
by looking at the tbi heads (187)
compared to tpi (081)
u can see the difference
081 has good intaake flow crappy exhaust
187 is the opposite crappy intake good exhaust
now for good power gains with all the work ive got done to my 081
ibelieve i should have got some porting ...
now any opinions would be fantastic
just a small bit of porting to make the 081 exh match the 187 exh!
u think this is worth the money or should i go higher???? or stay stock with the heads
and leave it alone with three angle valve job and resurfaced (11 thousandths i believe) and new springs to handle a 530 lift
doing lots of research during the build helps for info!! but always should do before u start the build
geuss i like learning the hard way
Car: 92 firebird
measurement wise like stock to. . . . . thanks!!!!
ok so seeing if everything goes well ith injectors i have
all i need is a rear!!
decide to repin my harness basically convert the87 ires i need to my 92 ire harness
then from a fello member get the 92 ecm ich i believe conection should be the same so this builds getting intersting with lots of knoledge gained
the connecter on the fire all going to make a drawing comparing pins then combine them to fit if all goes ell should do right correct me if im wrong
one PROBLEM!!!!!!!!!!!!!!!11
this wire broke idk wat its connected to if its important maybe egr?
like i said first build learning as i go
Car: 92 firebird
well finally decided to go with a full port on the 081 for 175 u cant beat it
should work well with lt1 and for a future build on a 350
probably want go to crazy will do more research on it tonight
well in the mean time to day was the start of a lil installing
started with the breaker bar and head bolts afterwards move torawards the cam
my dad and me cut the dowel pin with i held he cut heres a pic of the l03 and lt1
first cut did it for me then measured it afterwards first cut was dead on!
the on the bucket and a lot of oil!
alll to keep lifters soaked
then slowly put her in after covering in oil folllowed by lifters then that spider thing on top lol
more to come!!
more to come!!
Car: 92 firebird
i dont see how it seems understandble to me???? ? ? ?
what part doesnt seem right?
no point in going into every lil peice of info not aiming for a sticky. . . short and simple with pics
point it out and i will fix it
Car: 92 firebird
no progress yet accept for a throttle cable
but been collecting alot of parts for this build and selling alot of parts as well
have everything accept for three things
wire harness
rear end (found)
and rear 16 inch rims to fit the rear end
and some feul stuff
i have found alot of parts that i need no to get my hands on them
i got my hands on 3.42 posi with disc brakes but i need sixteen to fit these brakes.
thats what lead me to the irocs found em on ebay for cheap and they are sixteens so hey why not!! they look good on 92 birds in my opinion!
so really excited to finish this build for a cruise!
wire harness
rear end (found)
and some feul stuff
Engine: 4++,350 & 305 CIs
FYI instead of cutting the cams pin, you could have tapped it in with a brass hammer. (hole should b long enuff).
The wire on the egr your pointing to can b left off if you dont have smog testing. I have had mine unplugged since ive owned it an no check engine light or problems.
good luck with your build.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
For these cars you may also want to get an aluminum driveshaft as well from a 4th gen car. It reduces weight in your drivetrain and wont make your car shake at speeds over 90
Car: 92 firebird
i will keep this in mind although my car originally never shook over 90
still woul look into
i geuss to tell if u have one would be the wieght or a part number thank you
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Where in NC are you again? Im in the Durham/Hillsborough area
Car: 92 firebird
nufnuff is that ure z28 shes a dime!
well its been a while since i updated have alot thats stopping me. . .
like a broke bolt in the block ich i hope to fix tommorow
and timing gear problems. allso waiting for my heads from lane speed shop greates work for the greatest price! if anyone lives near the belmont area highly reccomand lanes speed shop for some machine work!
while waitn have collected alot!! more than enough lol.
got all the gaskets for the top end and head bolts,(all from fel-pro) then for the rearend i will be recieving i got some 16" stock irocks that i decided to customize a little.
so now it a waiting game a long one. . . . . .. .
if i can pick up my heads tommorow ill get to start building!
but heres a question probbaly a stupid one can i use my intake bolts from my tbi (hex bolts) on my tpi intake? (originally star bolts)
thanks and more updates tommorow
Car: 92 firebird
got the old heads off and the ne ported n polished ones on! they look amazing now to find some good valve covers or make my stock ones look good get the ported/polished intake an plenem and runneres tommorrow so she going to look good!! pics below
i was thinking to get headers on the passenger side to remove the starter anyone else had to do this?
regarding the headers
im havein the hardest time getting my stock y pipe off so i figured i leave it on and let the shop deal with it once the motors done onward torwards the rear!!!
Car: 92 firebird
out with the old in with the new!!
heres the new head gasket
now for pics of the heads installed on the block
if only i had access to some good valve covers for cheap
more pics soon!
more pics soon!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Did you get the cam gear figured out?
Car: 92 firebird
i came to a conclusion,
but i am still crazy confused about it.
i will just have to get a new one . . .
or go back to stock and get a new chain
never would have thought that would have happens a part from autozone says that it ill fit and doesnt???
im sure the bolts should not hit
idk if anyone else has used the duralast timing set but if anyone has and had the same problem plz post it could be possibly just a faulty part . . .. .
if not others should stay away
imm just going to buy the double cam gear part if i can find it
still strange
still strange
Engine: Lb9
Transmission: M20
if the stock one clears it I would look for another set, don't put a stretched out chain back on.
Car: 92 firebird
i was going to get a new chain seem to be a good idea
but good news got my ported n polished intake back and these baby look amazing amazing!!! so no in the future im going to get some slps for maximum flow pics soon
Car: 92 firebird
got some building done today not to much just got driver side header on and rocker arms and pushrods.
was abot to install the new intake and use my old intake bolts but the were different lengths even the ones without studs! and used my book but all the had was a pic of the tbi intake and ofcourse was impossible to know wich bolts go where compared to my intake...
call me stupid but i couldnt figure it out and didnt anna take chances of messing anything up.....
i have some questions plz fellow tgo members help!
for tpi do u even need the bolts with studs on top??
(i dont recall them on anything for the tbi . . .)
and can i use any intake bolts?? dont feel like dropping 69 bucks for intake bolts
found some summit ones for ten..
87 intake to 91 heads
also this caught my eye
the tbi intake on the front curves withe the block
my 87 tpi intake does not curve with it????
its strange bolts up but hangs over the block on the front .. is this normal?????
plz help thanks
plz help thanks
Car: 92 firebird
Been a while since i posted!
So heres wat has been completed
headers
manifold
runners fuel rail plenum
it all looks great went through some troubles though..
i started with the headers before i went to work also before it rained.
headers
the driver side was easy slid it down put the gasket over took a bolt and slid it in the the middle hole. hand tighten the bolt then did the rest as well.
the passenger side wat a pain . . .
had to take off the hose from the radiator to the fire wall (idk what it is called forgive the ignorance) then had to drop the starter got the header on and tighten the bolts! followed by putting the starter on.. had to leave that one hose off and figure a way to reroute it
over all looks amazing with them on and mean
then my next day off onto the intake
INTAKE
on towards the intake this one gave me some problems alot!
put the rtv on then the intake gaskets followed by the manifold a pain to align!! after countless attempts it was finally alignedso i went onto the bolts.
tighen them down according to the pattern in the book was a strange one but got it down. then torque em to specs heres the problem three bolts stripped not the bolts the heads . . . ..
so here i as stumped i mean seriously disappointed.how could this happen ?am i done, is this it? i felt like giving up . . ..
i sat down and rested and thought hard with disappointment ... called autozone, talked to a fellow grease head tim. that i know had to have went through this.
he said ouch lol
either drill em (i wouldnt machine shop would)
or try smaller bolts. . .
decide to sit down again..
went to my bag of old intake bolts and said why not try em...
tighten them and they stayed tight !!! relief!!!!!!!!!!!!!!!was so happy no more tightening that leads to it being loose just tigh to tight!!was soo happy then with my old gooseneck use that bolt for one of the holes and same thing!
so was happy although i believe the goose neck bolt could be a problem in the future but ehhh only time will tell
fuel rails and runners
trial and error with this one put the fuel rail on first then loosen the them the put on the runners tighten them down . . . then had to loosen the bolts the ru nner to get to the certain boltson the rails,
this kept repeating itself. ..
got the gaskets on and all found out i missing bolts for the runners to plenum
and the plenum would not line up so going to handle this time tommorow for it was gettin cold and i had holes in my shoes .......
here are the pics enjoy!
love the look so far
headers
manifold
headers
INTAKE
he said ouch lol
Car: 92 firebird
heres the sensors i wanted to post to make sure it was right
i believe this coonects with a hose to the valve covers on the driver side
and the sensors are right i hope let me know guys
got messy with the rtv!
and anyone kno where to get these bolts from?the ones that coonest the runners to the plenum?
and has anyone tried a hei dist on tpis? and wich one thanks
Car: 92 firebird
not much done waitin for the harness and some other bolts to get building!
this build took longer than expected but have learned alot!!
decided to go with black/polished iroc rims to fit the brakes !
cant wait to get this done!!!
Car: 92 firebird
helllo to all! mainlyy myself
Got alot done here lately stopped building cause i want to wait for all my parts to get here
so when i finish my build i will start adding lots of pictures and better info since it is hard to follow
EVEN though i after helping a fellow third gen owner put his rear end up under his beautiful ride, took a cruise in it me and the lady with him and i fell in love with lsx motors and ford rearends!!!
so when ever i can save will be time to throw that in my bird!
Engine: Lb9
Transmission: M20
Car: 92 firebird
Future builders if you need help ask this guy he will take good care of you
thanks tuned performance for looking out im uploading th epics now
Car: 92 firebird
Well here some updates for me to read
weathers been bad well atleast it has for everyday off i have. . . .
so im getting little done at a time
while waiting for parts i attacked the the fuel pump with out touching the fuel pump. . .
i jacked the rear took off the shocks wonder bar and brake line bolt to hold them down then let the rear axle sit on stands. then my adhd kicked in when other parts arrived so i attacked others hear some pics of the car jacked
drums
drums
Car: 92 firebird
after setting lash wich im going to double check before i start her up
my wire harness came in from POCKET and man it looks good thanks to pocket so i will just describe my easy way to put it in
with a wire guide in one hand nd the harness in the other i just threw the harness on top off the motor as the pic shows
then took the ecm connectors and pushed them towards the cockpit
then try to follow the connectors since pockets harness was labled help this first timer out with my harness!
i open the book found the sensors and connected them.
not hard at all just really time consuming.But i found it easier to connect the driver side ,injectors, etc then followed by the passanger side
here is how she sits now with the harness in
warning crappy pic
you cann see it doesnt look bad i think i did great theres stll hoses gotta connect
For the record thisn did take alot of time due to the fact i would connect and then disconnect then connect etc etc , just to route it right once again thanks to pocket!!
warning crappy pic
Car: 92 firebird
If anyone realized the pics of the ac setup in my car. . well its terrible lines were all bent and kinked.
so i went to pulla part and picked the whole setup minus the clutch for fifty five bucks!!
then put her in and she looks good !
i will soon be going for a good ac clutch and condensor to hopefully help my ac work!
just waiting for fuel lines and some parts from jegs then i should be done with the motor minus hoses wich brings me to a question
the vacums on the side of the throttle body are they needed?
if any one can help out with vacumm lines por send me in the right direction also removed the smogg pump
so more to come soon!
once im done with this and starther up and hope she work fine i will describe difference . But even then the build will continue with rims lowering shocks and rear bushings also front and a new rear money is limited though!
so thanks for reading
to be continued.. .
to be continued.. .
[QUOTE=dabird07;5147186]
QUOTE]
Looks like you may have a TBI balancer and a TPI timming cover. Better get that figured out for sure before you get the water pump on..
QUOTE]
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
lookin good wat did you do for your fuel setup any upgrades on that?
Car: 92 firebird
[quote=TTOP350;5147245]
it is a timing cover that my dad gave me i liked the chrome look and yes its a tbi harmonic balancer and the water pump fits fin and i can see the timing tab worse comes to worst ill time by ear
i havent even dropped the tank yet hoping i have enough room how it stands now
but the fuel pump im kinda sketchy on i have a walbro with a stock regulator and injectors dont know how well it will work though leads me to a question fo whom ever
just in case that walbro works wich is a good pump
acdelco?
airtex from autozone
a elderbrock
or accel?
also maybe should get better injectors and regulator?
thanks for the comments !
acdelco?
a elderbrock
or accel?
