larger idle air bypass hole for a 383 TPI?
Old Oct 26, 2011 | 09:49 AM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Didn't see anything directly related to this so I figured I would post.
My vortec 383 runs a little rich at idle. Surges a little bit, and stalls at idle on occasion. The IAC is set correctly, though I have to open it a bit more for minimum idle air rate compared to the 350 (obviously).
Naturally, the idle air bypass hole in the throttle body should be sized for a 305 (as the intake is). I'm assuming that the jump from a LTR 350 to 383 is causing my instability at idle, considering I'm using a stock ported throttle body.
Cammed LS1 cars often use this as a mod to smooth out idle instability issues.
Has anyone enlarged their idle air bypass hole to smooth out the idle for a larger engine, and if so, what size did you punch it out to?
Old Oct 28, 2011 | 01:50 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: larger idle air bypass hole for a 383 TPI?
Ever thought of just opening the throttle blades more with the set screw? What is your IAC counts at idle?
(Woops you have a totally different computer setup then I thought, don't think it would apply)
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
wruiz
Aug 13, 2015 09:07 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
