Intermittant no spark / Engine cuts off
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
Hey, I was driving a few days ago and my engine just shut off. No sputter. No misfire. Just cutoff as if I turned it off at the column and it would not start up again. Engine cranks but does not fire. I spent about half an hour trying to start it again and eventually it did, but it cut off again after about a minute of running.
Yesterday morning it started right up, ran for about two minutes and then shut off again and would not start. Verified that the fuel pressure is where it should be.
Today I hooked up a timing light to check for spark while cranking and there was none. After checking EVERY connection having to do with ignition I tried again and the timing light lit up and the engine fired. Damn thing shut off again after about five seconds. Spark gone again. I can't determine if I have a bad connection or if this could be some component that went bad.
By the way, 87 IROC, 5.7L TPI. Thanks for any suggestions
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: Intermittant no spark / Engine cuts off
Bad Ignition Control Module under the Dist. Cap or a bad pickup coil under the cap. Both are the most likely causes.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
been there , done that . good luck .
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
iv had 3 pick up coils do that with my 3rdgens. yet it very well could be the icm, alot of people have bad luck with those. the pick up coil is harder to change, but its a cheaper part. the icm is easier to change, but more expensive part.
Car: 87 IROC
Engine: 5.7 TPI
Thanks for the responses. I did consider the pickup coil and the ICM but I replaced the distributor with the Summit version. It only has about 6000 miles on it. Does anyone know how to test those items? I'll do a search also. Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Engine: Lb9
Transmission: M20
I had the pickup coil fail on me and a week later the module. I will allway replace them together cheap insurance. are you getting injector pulse ???
Car: 88 IROC
It also could be the actual external ignition coil failing. My factory one went bad and so did an Accel one I had. They also can cause the same problems as the ICM and pickup coil. Just an FYI that Summit dist. is made by Proform and I have seen a lot of there ignition parts fail very early.
Car: 87 IROC
Engine: 5.7 TPI
Well I just finished checking the ignition coil, pickup coil, distributor cap, rotor, voltage at batt terminal for ignition coil, and ECM connections(just because I have resolved a loose connection at the ECM in the past). ALL check out. I did not check injector pulse but I confirmed that there is no spark at the plugs. Sooooo, I guess it HAS to be the ICM. Since I can't really test that and I THINK I checked everything else, I'll pick one up and let you all know if Proform failed again. Thanks.
Car: 87 IROC
Engine: 5.7 TPI
Tunedperformanc, thanks for the link, there were some good diagrams that will be helpful.
Car: 87 IROC
Engine: 5.7 TPI
OK gentleman, and ladies, it was the ICM. I farmed the original from my old distributor and it fired right up. Just because I love to waste my time, I put the Summit ICM back in to double check that something wasn't just loose, but no, it was garbage. Put the original back in and I'm back on the road. Thanks for the assistance, fellas.
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Make sure you put Die-electric (spelling?) greese on the bottom of the ICM when you install it, helps keep it cooler and less prone to fail.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Does anyone else want to explain why bench testing ignition parts is a waste of time?
Car: 88 IROC
Car: 87 IROC
Engine: 5.7 TPI
Yeah Stealth, I put some grease under the ICM before installing it. And Burnout, thanks for the heads up about Proform making Summit's ignition equipment, I will definitely avoid them in the future. I don't know how long the original will last being that it is about 24 years old now, so I think I will pick up an MSD and keep the original in my road kit for a back up.
Car: 87 IROC
Engine: 5.7 TPI
Engine: Lb9
Transmission: M20
I agree, but the results can sometimes be off without heat soak !!
Engine: LB9, LB9
Bingo, it has to do with the duration of the test and the ambient temperature. A bench test is not going to replicate the situation therefore electrical parts can stil test "good" when in fact, they aren't.
Engine: Lb9
Transmission: M20
BINGO, damn I thought we were playing connect 4
Car: 87 IROC
Engine: 5.7 TPI
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Engine: LB9, LB9
Car: 88' IROCZ
Axle/Gears: 2.77
If I should need help in the future I sincerely hope you won't be a "dick" about it. I would still ask for help, the worst that can be said is no.
I'm all for bench testing because with all things being equal it proves the ICM is faulty and I wouldn't have put it back in just because it worked on the bench. That is why I bench test.
I'm a fluid flow experimental technician. I do not rely on bench testing and computer simulation alone, to see what's going on we use clear plastic to build a bench scale apparatus and clear pipe to make connections, unfortunately we can't apply heat which, in a refinery there's not much you can do without heat. The ultimate test is in the field where heat will be applied.
Raul.
eightsixseven
Dec 16, 2024 01:50 PM
