89 iroc z rough idle at night/colder temp
Car: 89 Iroc Z 350 TPI
Engine: L98 350
89 iroc z always is hard to start and has spiffy idle when temp changes. I know it has something to do with the intake air temp sensor because i took it to advanced muffles (Memphis TN) and they are tryna charge a arm and leg to replace/fix it. Can someone help/tell me if this is a job i can do on my own and if so pictures and details are greatly appreciated. Thank you
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 89 iroc z rough idle at night/colder temp
The air temp sensor is for controlling the EGR function. You could disconnect the EGR to test if it makes a difference. The car should idle ok without either the MAT or the EGR. If you're going to attempt to fix yourself, then you have to start troubleshooting.
Engine: L98 350
well in that case ill probably take it back to the shop then lol...thanks man
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If that fixes it you can do the mat relocation kit instead of pulling the plenum there usuall $40 bucks and you can easly install it in your air filter cover.
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
