intake head help
Old Nov 24, 2011 | 02:31 AM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
intake head help
I have read on here that there are intakes from some years that fit 2.02 heads and... Is this the maf compared to map is that what changed or is there specific years?
Old Nov 24, 2011 | 06:57 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: intake head help
2.02 is size of the valve inside the head.
Nothing to do with intake port size to match the intake port.
A stock head of a certain port size (intake gasket ) may have been available with different valve sizes
Also nothing to do with the engine management type; MAF vs MAP
Old Nov 25, 2011 | 07:11 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I'm guessing that this is your question. Center Bolt holes on SBC Intakes changed in '87 to a different angle. If you are using older heads ( '86 or before), then the two center bolt holes on your intake will need to be slotted to allow the bolt the proper angle to fit the older heads. Alternatively, you can find an '86 or earlier intake.
Old Nov 25, 2011 | 08:09 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Yes that is what im askin like camel hump heads or somethin. i wasnt sure if it was the different intake the map vs. the maf cause i know 86 and what not was a maf and most after is map. but my 87 intake is maf so i wasnt sure if it would fit on other heads
Old Nov 26, 2011 | 01:04 PM
wehrlebird's Avatar
Car: 87 T/A
Engine: 383
Axle/Gears: 373
Guys,
I'm doing the opposite. I have an 86 TA and aquired centerbolt heads. Will the 86 intake bolt up to the centerbolt heads?
earlpote
Aug 28, 2015 10:42 AM
hayesaw0210
Aug 23, 2015 11:15 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
