how do you guys polish your runners?
Old Dec 8, 2011 | 12:37 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So I was reading on the tech page about polishing the tpi plenum but it does not say anything about how you polish the runners. Do you follow the same steps as the plenum polishing?
Old Dec 8, 2011 | 12:44 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
Re: how do you guys polish your runners?
i am in the process of polishing a set of runners just lots of sanding and time i am using a bench grinder with buffing pads and tripoli compound works great
Old Dec 8, 2011 | 01:44 PM
Car: 91 formula
I was planning on doing this by hand as part of my winter project. What grit sand paper should I start out with and finish with?
Old Dec 8, 2011 | 07:26 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
300 grit, 500 grit, 800 grit, 1000 grit, 1500 grit, tripoli, diamond polish
Don't go past 1500 grit, it won't buff out as nice.
Old Dec 8, 2011 | 07:58 PM
Car: 91 formula
thanks for the tip.
Old Dec 16, 2011 | 10:35 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Honostly, I would chrome them. Polished aluminum scuffs extremely easily. A clean finger can scuff a highly polished aluminum finish. Chrome, well it is some pretty tough stuff. You can wipe it down with a rag and not worry about scuffs. Just a thought.
Old Dec 17, 2011 | 12:19 AM
Car: 91 formula
yea. Tonight i just started sanding down the top plenum. im starting to see some fine scraches on the plenum. Im sure the more i sand they should go away. but yes Im trying to think twice about sanding the runners.
Old Dec 17, 2011 | 03:09 PM
lb9 GTA's Avatar
the plenum takes some work put the runners go easy
Old Dec 17, 2011 | 05:21 PM
Car: 91 formula
have you done this to your tpi system. Do you have any pics. I was thinking of starting with 500 grit on the runners and move up from there.
Old Dec 18, 2011 | 01:00 PM
lb9 GTA's Avatar
I have done it to mine. Believe it or not I did the first cut on my runners with red scotchbright pads. 500 grit would be a good start 'cause the tubes are fairly smooth to start with. Only takes a few minuts to do compaired to the plenum which took me more hours than I'd like to admit.
Old Jan 3, 2012 | 12:04 AM
Car: 91 formula
here is an update picture
Attached Thumbnails how do you guys polish your runners?-polished-plenum-finished-pics
Old Jan 3, 2012 | 01:30 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I polished mine, but two years later, I wish I had gone the Powdercoat route. It's hard to keep them shiny. I have heard that Clear High Temp paint might help ( also heard that it yellowed over time).
Old Jan 4, 2012 | 01:50 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I know it's taking the easy route, but I just painted my plenum and runners with high temp aluminum paint, followed by high temp clear. I wanted it to be easy to clean once it's back together.
Old Jan 4, 2012 | 03:55 PM
Car: 91 formula
its that true. If so that sucks. Any way I can protect my shine.
Old Jan 4, 2012 | 07:54 PM
lb9 GTA's Avatar
Rub them with polish every once in a while. Mine was done 2 years ago now and still shines like I just did them.
Old Jan 4, 2012 | 08:53 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I ground all the rough casting down with the little 3m "cookies" for a die grinder. Polished them back up with an aluminum polishing kit from eastwood. Was covered from head to toe in black when I was done and it took the good part of a saturday. Just hit it with some polish occasionally. Did the same with my miniram. They look better in real life then with the pics. They were taken before all the modern advances in cell phone camera technology lol.
Miniram still has some of the black stuck to it in these
Old Jan 4, 2012 | 11:05 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
just finished mine orignally bought a set but decided to do my own
Attached Thumbnails how do you guys polish your runners?-2012-01-04-2022_42_31.jpg   how do you guys polish your runners?-2012-01-04-2022_42_41.jpg
Old Jan 5, 2012 | 12:46 AM
Car: 91 formula
looks very nice guys. I have heard once they are high polished like this you are not to use any metal polish on them again.
Old Jan 5, 2012 | 06:52 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I just polished my First runners which were a lot rougher than the stock ones. I like to use an orbiter sander to get most of it, then hand sand the hard to reach areas, and finally polish. Mine aren't as nice as others that have posted, but I'm happy with the results.
Old Jan 5, 2012 | 12:49 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
it looks good did you use a white rouge on themn that really seemed to make them look mirror like
Old Jan 5, 2012 | 02:20 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Yes, it's crazy how much the white rouge gives it that shine. I actually did 60, 150, then 200 grit sanding before I went right to the red, then white polish. I guess that's why they aren't quite a mirror finish like 89 350's, but I was tired of sanding.
Street Lethal
Apr 30, 2019 12:14 PM
tazs2000
Jul 15, 2017 08:44 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
kah992
Aug 19, 2015 02:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
