eaton m90 or maybe m112 supercharger on 305 TPI
Old Dec 15, 2011 | 04:15 PM
Rezi1987TA's Avatar
Car: 1987 Pontiac Firebird Trans Am
Axle/Gears: 3.45
I've received great help here and now I need it again :-)))
I've recently put a Crane Cams 104224 (Duration Advertised:270° Intake / 276°; Exhaust Duration @ .050'' Lift:214° Intake / 220° Exhaust;
Valve Lift w/1.5 Rockers:.452'' Intake / .465'' Exhaust). Otherwise the car is nearly stock. I have Granatelli MAF (which I don't really like...yet at least!) and Mallory adjustable fuel pressure regulator.
I want to put a m90 supercharger on the side of the engine. I know it has been done a lot of times before but here are the questions:
1) Would m112 fit above the left cylinder head or should I go with m90?
2) My injectors are faulty anyways. What size should I buy? And is it possible to fit the 7m Supra Injectors that I can have for free?
3) What size intercooler should I get?
4) What is the most boost I can run to keep it safe?
5) I cannot tune my car anywhere. So I'll have to order a custom burnt PROM. Whom would you advise?
6) Any other advises?
Hope to get help here again :-))) Otherwise I'm in deep **** :-))))))))))
Old Dec 15, 2011 | 09:45 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Re: eaton m90 or maybe m112 supercharger on 305 TPI
Just curious how is the car running with the Crane 2032 cam? I remember when you were asking about it.
How did the install go?
Old Dec 16, 2011 | 05:06 AM
Rezi1987TA's Avatar
Axle/Gears: 3.45
It ran really well at the beginning! I didn't expect it to be that smooth...I upped the fuel pressure to 50 psi (but I think it's still not enough) and it ran quiet a bit better than before. But than the injectors started to die :-((( I knew that would happen anyways...
As for the power. It shifted upwards on the RPM. I could shift later. It still started sort of choking after 5000rpm but that's probably because of my restrictive intake.
For comparison - my friend has a 91 Supra boosted at 1 bar (14.5 psi). There are no other mods done to it (besides the metal head gasket) and before I wouldn't even dare to race him We did it once from a roll and I was embarrassed :-))) After putting the cam he was still faster than me but he didn't "lose" me as before. And that was without my car running properly (dying injectors, no tune etc). If my car would run well it would probably be really close. Not really hoping for a win but a close race is a good race especially with a friend :-)))
P.S.: When both cars are stationary Trans Am beats the s**t out of a Supra :P it's so much more evil! :-))))))))
Old Dec 17, 2011 | 02:24 PM
Rezi1987TA's Avatar
Axle/Gears: 3.45
Anyone? :-S
Old Dec 18, 2011 | 07:27 PM
burnout88's Avatar
Car: 88 IROC
Glad to hear everything went well. You may want to post this question in the Power adder section of the forum. Would probably get a better response over there on a supercharger question.
Old Dec 19, 2011 | 02:02 PM
Rezi1987TA's Avatar
Axle/Gears: 3.45
Thanks a lot. I did that already :-)))
Old May 25, 2012 | 04:36 PM
nathan44's Avatar
Car: trans am
Engine: 5.3 l59 flex
Transmission: 4l60e
U have pictures of the build?
Old Jun 28, 2012 | 01:53 PM
Rezi1987TA's Avatar
Axle/Gears: 3.45
Sorry for the late reply. I haven't done anything with it. I bought a 300zx (which I'm rebuilding now) and my firebird is a daily driver now so I can't start building anything. I might do it later and will post pics.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
