Hey all
I have been offered by a member of this forum an Accel super ram TPI base that apparently has been drilled to fit Vortec heads. He was using it on his 92 L98 and prior to that it was fitted to a 355 Vortec headed engine ( same as I am building). I need to know if this base is ok for Vortec heads as I thought they had taller ports? Thanks for your help in clearing this up for me before I purchase.
you can't just drill for vortec heads. If its drilled it came that way with the duel bolt pattern 55-86 87up. you will need a scoggen dickey tpi vortec manifold or edelbrock 3817.
http://www.gmhightechperformance.com...d/viewall.html
depending on the manifold you can re drill the heads
http://www.bhjproducts.com/bhj_conte...ng/mdf_vdf.php
Originally Posted by tunedperformanc
you can't just drill for vortec heads. If its drilled it came that way with the duel bolt pattern 55-86 87up. you will need a scoggen dickey tpi vortec manifold or edelbrock 3817.http://www.gmhightechperformance.com...d/viewall.html
That was my understanding too. I knew I needed aVortec specific base but have no experience with the Accel super ram base .
depending on the manifold you can re drill the headshttp://www.bhjproducts.com/bhj_conte...ng/mdf_vdf.php
I see how you can redrill but that doesn't address the port alignment miss match so what would be the point?
the intake port would have needed to be raised. and these gaskets would need tobe installed. I would ask for a picture. would have to be modified manifold with alot of fill work.
http://www.summitracing.com/parts/NA...7760/?rtype=10
the intake port would have needed to be raised. and these gaskets would need tobe installed. I would ask for a picture. would have to be modified manifold with alot of fill work.http://www.summitracing.com/parts/NA...7760/?rtype=10
Already asked for photo as I had my doubts, see what happens, thanks for your advice.
Std intake on Vortec port
( the aftermarket Vortec heads shown have both bolt patterns )
Its doable, but without the skills and the base to start with, isn't really worth it. Anyone with machine shop skills and a tig welder can make the accel base work, but for the average guy, just buy the correct intake base.
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,148 Times in 749 Posts
Quote:
Chicks dig guys with skillzOriginally Posted by dhirocz
lol not those kinda skillz
I'm building my Super-ram Scoggin Dickey Vortec manifold right now. You will need to clearance the intake manifold because the mounting boss for two of the intake bolts will not allow you to fit the Accel Super ram runners. You'll also need 2 flat headed or button headed bolts.
