42lb injectors ?
Old Dec 17, 2011 | 03:18 PM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
42lb injectors ?
wasup peoples
i am on a mission to make about 500hp at the rear wheels of my car.i know that a chasis dyno take a way a lot of power.here is my setup.
engine
400sbc bored 0.080,
heads
aluminum cnc ported,2.08 in\1.99ex valves,220cc runner,68cc chamber,5 angle valve job,angle spark plugs
cam/rocker arms
comp xfi 292 exreme efi cam/1.65 full roller rocker arm
cam spec are below
Basic Operating RPM Range2,800-6,800Intake Duration at 050 inch Lift248Exhaust Duration at 050 inch Lift253Duration at 050 inch Lift248 int./253 exh.Advertised Intake Duration292Advertised Exhaust Duration302Advertised Duration292 int./302 exh.Intake Valve Lift with Factory Rocker Arm Ratio0.584 in.Exhaust Valve Lift with Factory Rocker Arm Ratio0.579 in.Valve Lift with Factory Rocker Arm Ratio0.584 int./0.579 exh.Lobe Separation (degrees)113Computer-Controlled CompatibleYesGrind Number292XFI
42lb injectors venon
rhode island variable lifters
ign and ecu
efi connections 24x/ls1 ecu
elderbrock pro flo xt with ported ls1 tb
maf sensor
my question is should i move up to the 60lb or stay with the 42lb to get near 500 hp or higher. range on a chassis dyno
Old Dec 17, 2011 | 03:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 42lb injectors ?
Lets start with this.
I hope your not planning to bore a factory 400 block to .080..
Old Dec 17, 2011 | 03:55 PM
kad5118's Avatar
Car: 91 gta ws6
the engine is together and is running with everything that is listed above.its a 408 sbc.
Old Dec 17, 2011 | 05:07 PM
TTOP350's Avatar
If its a 408 then its bored .040 over.
If you went much more your reeeeeally pushing it with a 400 block, even with sonic testing shes getting thin unless you got super lucky..
I haven't got mine to the dyno yet but I'm going with 60s
Old Dec 17, 2011 | 05:12 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Maybe it's a Rhode Island block ?
I mean aftermarket block.
At any rate, 42 lb injectors are more than enough to handle 500 rwhp.
Old Dec 17, 2011 | 06:17 PM
kad5118's Avatar
Car: 91 gta ws6
she is built by a professional.400 block are more sturdy than what people actually knows.do you have a 400sbc.
Old Dec 17, 2011 | 06:22 PM
kad5118's Avatar
Car: 91 gta ws6
rhode island is a after market company that make lifters.they have been around for such a long time. but the block is stock gm block
Old Dec 17, 2011 | 08:25 PM
TTOP350's Avatar
Yes I have a GM 400, 509 2bolt block with splayed 4bolt mains. I've even broke a few 509s.
I have some crete in it to stifen the walls.
Forged crank eagle rods and JE pistons.
Did you sonic check the thrust side of the bores??
Nuthing wrong with a 408 at all as long as the walls are thick enuff for proper ring seal even after several thousand miles.
I had a guy going from a .030 over to .040 over and he cracked 2 cyls boring them. They were super thin.
I know of rhodes lifters.. http://www.rhoadslifters.com/ I didn't know they were still around.
Never heard of rhode island lifters???
Old Dec 19, 2011 | 07:47 PM
kad5118's Avatar
Car: 91 gta ws6
the engine was professional built.
Old Dec 19, 2011 | 07:52 PM
kad5118's Avatar
Car: 91 gta ws6
is there any one running 42lb injectors their setup if so what type of power are you guys getting.any feedback would be greatly appreicated
Old Dec 19, 2011 | 08:04 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
I dunno much but Im aiming for 490 at the fly. Do a Google search for fuel injector size calculator. It is based off of several things including HP. Plug in your variables and it should give you a fairly accurate number on the injector size that is required for your setup. If that size isnt available, round to the nearest size injector that is.
Old Dec 19, 2011 | 11:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
One more time. 42 lb/hr injectors are WAY more than enough to produce over 500 horsepower at a reasonable RPM - 6000.
Sizing injectors for a max of 80% DC is overkill in the first place.
On top of that you have the freedom to up the fuel pressure as/if needed should the situation arise.
Old Dec 20, 2011 | 07:39 PM
kad5118's Avatar
Car: 91 gta ws6
other inputs besides yours sir thank you
Old Dec 20, 2011 | 08:29 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
My friends 406 victor EFI motor is making 521whp thru a 6spd. He is using 42lb injectors but they are at 55psi base pressure and about 85-90% cycle duty now.
If you can get 60's that will leave more room for error, but then again, you may be ok with 42's at higher pressure. I dont see your combo making quite 500whp if an automatic with that cam. It will be alot, mid high 400's if good compression/ring seal in that motor but it needs abit more lift and duration to really make 500whp. Whose heads? That intake may need some serious port work to help flow up top end too
Old Dec 22, 2011 | 09:55 AM
Engine: 5.7 LSX
You didnt say if you tried my suggestion or not. heres a link...
http://www.witchhunter.com/injectorcalc1.php4
Try that.
Old Dec 22, 2011 | 12:55 PM
kad5118's Avatar
Car: 91 gta ws6
Try that.
tried the link and it not working
Old Dec 23, 2011 | 03:51 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
http://www.rceng.com/technical.aspx
Old Dec 23, 2011 | 05:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Calculator seems to predict about the same as my buddy's 406. Figure 620 crank hp, 0.55 bsfc and 90% cycle duty, need about 42 lb injectors if you run them at 55 psig pressure.
If you wanted to use regular TPI 43psi fuel pressure, you should look into 48-55 lb injectors, whatever is available in that range.
Old Dec 23, 2011 | 08:50 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
wasup peoples
engine
400sbc bored 0.080,
heads
1.99ex valves
elderbrock
ALOT of misinformation going on here. You got some research to do. And 42's even sounds overkill for that combo.
Old Dec 24, 2011 | 03:59 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Even the GM Bowtie block only allows a max 4.185 bore(.060 over factory 400). The correct terms are Edelbrock, Rhodes Lifters(I don't of any serious engine builder today that uses them, although Gale Banks used to endorse them, so whatever), the 1.99 exh vales must be a misprint. Noone makes a small block head that takes 1.99 exh valves.
If you actually have this engine, and it was professionally bulit, you just spent alot of money on an engine you know very little about. As far as injector sizing is concerned, the size of the nozzles is a small part of the equation. I run 24 lb injectors and make over 450hp at the flywheel. I of course run the nozzles at 70 psi. More important is knowing your engine's peak fuel requirement and sizing injectors to provide that need when operated at at 80% duty cycle. That's why you need to use the injector size calculator. Try TPIS. They should have a calculator on their website.
Do your homework.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
