swapping injectors
Old Dec 24, 2011 | 12:38 PM
camaroboy199290's Avatar
Car: 89 iroc
Engine: 355tpi
Transmission: jasper 700r4
Axle/Gears: 4.11 lsd
swapping injectors
alrite so i have a 305 tpi car and it has the 350 chip in it so its runnin a little lean i have a set of 30lb injectors and i was thinking to put them in instead of the 19s. and yes i no its gonna run a lil rich but would it b to rich that it would bog down the motor or just a decent gain over the 19s??? and the only other thing done to the car is headers and exhaust and k&n filters
Old Dec 25, 2011 | 10:02 AM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: swapping injectors
IMO. 30 lb injectors on a 305 will be way too rich. I don't think you will be happy with them at all. You will need a tune on the chip to even get close to running well on 30 lbs. Since you will need a tune anyway, why not get the chip you have re-tuned for the 19 lb injectors you already have?
Old Dec 25, 2011 | 10:42 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
30 lb would be way way way too rich. It would cause you some problems including damage to your engine.
Old Dec 25, 2011 | 10:59 AM
85IROCzzz's Avatar
Car: 91 Z28
A stock 350 even only has 22lb injectors so you can imagine how big of an overkill 30lb would be in a 305.
Old Dec 25, 2011 | 11:14 AM
89shane350's Avatar
Car: 1989 Chevy Camaro IROC-Z
Transmission: 700R-4
Axle/Gears: Borg-Warner rear axle 2.77
yea, just sell them on here or ebay and buy the 305 chip from autozone
Old Dec 25, 2011 | 11:42 AM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
.. What makes you think it's "lean"..? . Are you showing any Codes?
.. What's your fuel pressure... possibly a slight bump in fuel pressure is all you need to compensate for the additional scavenging of headers...
.. If putting the 30 lb. injectors in, also put a 460" engine in...
Old Dec 25, 2011 | 04:21 PM
Car: 89 iroc
Engine: 355tpi
its runnin lean cause it spark knocks with the 350 chip and the 19s and when i got the car it had the 30 on a stock 355 just bored out nothing other than a overbore and it ran decent just a tad rich
Street Lethal
Apr 30, 2019 12:14 PM
gta90
Sep 15, 2015 04:00 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Jae992
Aug 27, 2015 09:07 AM
tmellott89
Aug 16, 2015 02:58 PM
