What would be the effect of longer runners?
Car: 1991 Z28
Engine: 5.7 TPI
My apologies if this is a silly question, but I am new to this engine. What would be the effect of using TPI runners that are 1" or 2" longer? Do you have to do any tuning to compensate?
Any feedback would be appreciated...
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
Re: What would be the effect of longer runners?
.. The power band of the engine would be lowered a few hundred RPMs from where it is now.. torque might be enhanced a bit, but peak a couple/three hundred RPMs lower..
.. The current runners are already considered too long for engines bigger than 305 cubic inches... and hold down HP above 4500 RPMs on bigger engines...
.. '91 TPIs are MAP and don't self-compensate well to changes...
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Transmission: Many
Axle/Gears: Many
.. Those early 1960's Chrysler crosss rams came in a low RPM street version with full 30" runners and a race version with each pair of runners cast siamesed together for the first 15"...
Engine: 4++,350 & 305 CIs
And cold start on those older carbed cars was nasty due to fuel puddling under the carb..
Pac J
May 17, 2020 10:44 AM
Royal_Z
Sep 30, 2015 08:45 PM
