Cruise control vacuum hose, where on the plenum does it run to?
Old Jun 25, 2002 | 08:58 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
I swapped form TBI to TPI a while back, and want to know where the vacuum line running from the cruise control unit runs to. I think it's the vacuum port next to the FPR vacuum line on the rear pass. side by the dist....is that correct? Also, I think my TBI cable is too long, anyone know for sure if the TPI cables are smaller? thanks.
Old Jun 26, 2002 | 10:47 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't know about your cables but.........
the cc line does indeed hook up to the plenum by the fpr. depending on how much stuff you have and moved over it actually plugs into a 3 way valve that then plugs into the plenum.
Old Jun 26, 2002 | 05:41 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Thanks for the info....could you answer me one thing? The 3 way valve you mentioned, where do the other 2 lines run from?
Old Jun 26, 2002 | 10:00 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
One line goes to the plenum, one to the cruise, and one goes through the firewall to the HVAC controls.
Old Jun 26, 2002 | 11:09 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
AHH.....HVAC...that would explain why my AC hasn't been blowing out of the front vents....thanks. I took a look, and the only vacuum lines I see running to the firewall are the one for the heater control valve, and EGR....should there be another? I'll take a harder look tomorrow, but that's all I see. Anybody got a chart w/ that kinda stuff?
Old Jun 27, 2002 | 11:24 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The hvac line is combined with a mess of wires concealed in convoluted tubing between the heater box and coil on the firewall. At least it is on my 92 L98.
Old Dec 31, 2011 | 01:53 PM
Princess RS's Avatar
Re: Cruise control vacuum hose, where on the plenum does it run to?
Hello um i have a problem i have a regular 1990 camaro rs 6 cylinder and the cruise control there is this little nip that is suppose to connect to a line and well a friend told me that it might go connected to this ball that is located in the front driver side of the car behind the bumper he says that its like a conpresing chamber ? any one care to help O.O
Old Dec 31, 2011 | 05:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Should go to a T.
One vac line to above mentioned 3 way valve;
the other line to the vac ball
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
