Wiring 305 tpi from scratch
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys need some series help I pulled my 305 tpi motor out about 1 yr ago....but the wiring was completely messes up everything was cut or spliced....so I got a harness from somebody on this site...thing is this is my first time wiring up a tpI motor stop I need alot of help...I took out the c100 connector and the relays on to the new harness has all that stuff....I also left the light harness in there so...its really just everything going to the motor...I also took out the smog pump and ac and deleted the egr...i was messing with it yesterday but all the little connections that I have no clue what they are is killing me...i.don't want to pay somebody to so do it..but if I can't get it I guess ill have too, ha ha any help would be awesome thanks
Engine: 4++,350 & 305 CIs
Re: Wiring 305 tpi from scratch
I have done this stuff many times and its easy if you have a service manual. Big help and worth every penny! If you dont beg borrow or do what you can to get a wiring diagram. It'll be sooo much smoother after that..
Helm. new or on ebay. very pricey but worth it. Even google may have what you need.
Engine: 350 tpi
Yeah the only manual I have is the haynes one ......there is alot of little connectors that I have no see what they are and that's what's throwing me off.
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
most of the connectors only plug in one way so run ur harness in the car the way it should and look for things that could plug in close. post some pics of the things that u cant find a hook up for and maybe we can help.
Engine: 350 tpi
Yeah that's what I'm going to do...I separated the harness ratatat so this weekend ill be running it in the car as it should be then seeing what goes where..thanks
Sanjay
Aug 12, 2015 03:41 PM
