need help please running out of hope
Old Jan 18, 2012 | 11:54 PM
billy joe's Avatar
i have a 91 short bed chevy with a 90 model 350 tpi when i plug in the est wire it starts missing and running hot have replaced knock,fuel pump,tps,regulator,cap,plugs,ecm,icm,o2,please any help would be very much appreciated
Old Jan 18, 2012 | 11:56 PM
Alwaysboosted's Avatar
Car: Turbo Z31, RX7, and 2 F-bodies
Engine: 1.LS1, 2. L98
Transmission: 1.4L60E, 2. 700r4
Axle/Gears: 1. 3.23, 2. Unknown
Re: need help please running out of hope
Pulling up and checking out any and all codes would definitely help before throwing money at something without knowing what's wrong exactly.
Old Jan 19, 2012 | 12:07 AM
billy joe's Avatar
only code i get is code 42
Old Jan 19, 2012 | 12:09 AM
billy joe's Avatar
and it runs great for first 15 min
Old Jan 19, 2012 | 08:37 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Did you recently have the distributor out?
Old Jan 19, 2012 | 08:38 AM
ninetyone's Avatar
Axle/Gears: 3:42
code 42 is ignition system, where is your timing at now?
Old Jan 19, 2012 | 10:18 AM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
Shld set the timing at 6 degrees but I run my 305 tpi at 8 and its fine. Maybe the coil bad when they get hot they start acting up.
Old Jan 19, 2012 | 10:19 AM
ninetyone's Avatar
Axle/Gears: 3:42
Its unlikely, but i do know that when an ignition control module is bad they act up when they get warm or engine warms up.
Old Jan 19, 2012 | 10:21 AM
ninetyone's Avatar
Axle/Gears: 3:42
Let me ask you this: Are all your plug wires good? Start it up at night and look to see if you have any blue sparks on the outside of your wires (arching). This would act like a miss.
Old Jan 19, 2012 | 10:27 AM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
I have seen coils do this if they r bad an start getting hot they will arc jus like a plug wire does. Best to have a few spare parts laying around for trial and error.
Old Jan 19, 2012 | 10:30 AM
ninetyone's Avatar
Axle/Gears: 3:42
Thats true too. Mine had a blue spark going across it once. Coulnd't see it until it was dark outside tho. Thats how i found my bad plug wires too.
Old Jan 19, 2012 | 12:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the spark timing once the EST/BYPASS is re-connected and the engine is restarted. If it retards (likely) the pickup coil wires to the ICM are reversed. Note that you will need to key-off for at least ten seconds after re-connecting the EST/BYPASS connector, then restart the engine.
RBob.
Old Jan 19, 2012 | 05:26 PM
billy joe's Avatar
it does retard so what do i need to do
Old Jan 19, 2012 | 05:27 PM
billy joe's Avatar
they are all good no spark and they are all knew
Old Jan 19, 2012 | 05:28 PM
billy joe's Avatar
no sparks at coil
Old Jan 19, 2012 | 06:44 PM
billy joe's Avatar
RBob.
thank you i know me not knowing that makes me stupid for over looking it i checked it prob a dozen times never thought to look at the colors you made my day alot easier
eightsixseven
Dec 16, 2024 01:50 PM
92camaroJoe
Jul 29, 2023 07:57 PM
ezobens
Aug 19, 2015 10:29 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
