High idle when coming to a stop
Old Jan 23, 2012 | 03:20 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Okay i got my injectors replaced and overall the car runs good now, but I notice when I come to a stop the idle seems high, and then after I'm stopped for maybe 4 or 5 seconds the rpms will drop down to normal. Also if I stop and put it in park it will jump up to 1k rpm for about 5 seconds, then drop to 500 or so.
I feel like this is putting unnecessary wear on my brakes. Or maybe it's normal?
Old Jan 23, 2012 | 03:24 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: High idle when coming to a stop
IAC valve or if you disconnected the Throttle position Sensor when putting in new injectors, maybe needs to be re-calibrated....
Raf
Old Jan 23, 2012 | 03:26 PM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
The ecm keeps the rpm's up when coming to a stop, that is normal.
The jump by 1k when in gear seems excessive.
Did you ever get a chance to reset the minimum idle? (Now that you have the proper amount of fuel, it would be a good idea.)
Cheers
Old Jan 23, 2012 | 04:17 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
No, I never reset the idle.
The idle does eventually drop down to where it's supposed to be, it just takes a few seconds longer than other vehicles I have owned.
Wade787b
Sep 29, 2015 01:15 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86White_T/A305
Aug 17, 2015 12:16 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
