throttle body coolant lines....why?
Old Jan 30, 2012 | 04:16 PM
erik69&85's Avatar
I've got the top end pulled apart for a injection replacement and I have to wonder why the throttle body had coolant lines? To warm the air charge?
My 92Z still has all the original date coded radiator hoses and one of the TB lines recently sprung a leak so i had to replace. But regular heater hoses won't make that bend to nicely. Had to put a large diameter spring inside to prevent it from collapsing.
I hear about others with a TB bypass setup. Is it just routing the coolant line around the TB or do I actually need to buy something?
Pluses and minuses of running coolant through the TB?
Old Jan 30, 2012 | 05:03 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: throttle body coolant lines....why?
It's there to prevent throttle body icing in real cold conditions, your fine to bypass it
Old Jan 30, 2012 | 05:04 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
if you drive your car in high humidity/low ambient temps, your TB will begin to ice up in short order.that is the purpose of running coolant thru the TB.its ok to delete it if you live, say in phoenix AZ. or some other gates of hell hot climate.
Old Jan 30, 2012 | 08:48 PM
87rattler's Avatar
Car: 87 Iroc-Z28
I needed that hose last year and NAPA had them. I had to take the original in and they matched it up.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
