Throttle Return Spring 2.8L TPI?
Old Feb 4, 2012 | 01:07 AM
wiley1kinobe's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 5sp Manual
Axle/Gears: Stock
Can anyone tell me how invloved rewinding the throttle return spring on 2.8L v6 fuel injected RS is? Has a carb spring to pull the throttle back to idle. Sometimes it sticks at stop lights and revs to 400 RPM. I have to tap the gas pedal to get it to release. Help please! Trying to get my RS back on the road to be my daily driver.
Old Feb 4, 2012 | 08:53 PM
Damon's Avatar
Re: Throttle Return Spring 2.8L TPI?
Hmmmmm...... should be a simple process of twisting the spring BACKWARDS against the normal direction of throttle shaft rotation so that it's pre-loaded against it and always trying to close the throttle. There is a "catch" on the throttle arm where the spring end hooks onto the throttle arm.
I suspect there is more going on here or the previous owner would simply have done this instead of resorting to an external "helper" spring.
maroe624
Apr 16, 2017 08:29 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
