Injectors-Supplier and Brand-Who Do You Recommend?
Old Feb 5, 2012 | 04:57 PM
91Z28fan's Avatar
Hi members,
I need to buy a complete set of #19 lb. fuel injectors for my '91 305? I have heard Bosch IIIs are a good choice, but not sure. Would you suggest new or remanufactured? Thank you.
Old Feb 7, 2012 | 03:15 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Injectors-Supplier and Brand-Who Do You Recommend?
http://www.southbayfuelinjectors.com...o_305_TPi.html
Old Feb 7, 2012 | 03:22 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
I prefer Ford/Bosch yellow top injectors, they are more or less a drop in replacement for a 305... I paid $20 for my set of 8 from a junkyard ford used them in almost everything for awhile so they are cheap and plentiful.
Old Feb 7, 2012 | 04:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I second the southbay recommendation , don't forget to use your tgo 10% discount !
Old Feb 11, 2012 | 09:47 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
i third southbay. great turn around time and awesome service.
Old Feb 11, 2012 | 10:41 PM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
two weeks i'm upgrading to 60lbs and my 22lb bosch 3's from southbay are up for sale. make you a deal if you want them
Old Feb 11, 2012 | 10:43 PM
this time i'm using fuel injection connection
Old Feb 12, 2012 | 02:12 AM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
I agree southbay is the best to get the correct injectors for our cars and they are amazing
Old Feb 12, 2012 | 08:35 AM
Only problem with southbay is they don't have tuning info for the bosch 3s besides flow rate
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
