Carbon Build-up inside plenum. How do I clean it?
Old Feb 18, 2012 | 11:11 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Sup guys. I know this may be a dumb question. But how did you guys clean up the inside of the plenum?
Old Feb 19, 2012 | 10:25 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Carbon Build-up inside plenum. How do I clean it?
Remove the plenum and get you a can of brake cleaner. Make sure you remove the sensor located on the bottom of the plenum before you get started. Brake cleaner will clean it right up. Make sure you wear some eye protection. You might want to go ahead and get an upper intake gasket kit. The gaskets will very likely come apart when you remove the plenum.
Steve
Old Feb 19, 2012 | 12:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
caster oil super clean.
gta892000
Aug 11, 2019 11:16 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
mud runner
Nov 2, 2015 07:30 PM
64Chief
Sep 12, 2015 08:05 AM
89fast5oh
Sep 8, 2015 09:55 AM
