Procharger on semi stock 305 tpi
Old Feb 20, 2012 | 11:17 PM
1988TransAm22s's Avatar
Car: 1988 TRANS AM procharged
Engine: 305 procharged TPI with 5 speed
Transmission: 5 speed
Axle/Gears: 3:73
i just picked up a complete procharger kit from a buddy of mine with less then 500 miles on it... I am planning on runnning it this summer for some more go power..From what ive read in the instruction manual it says this is set up for a stock 305 and that nothing else is needed to run this set up..Is this true...I believe its a P600B setup..9lb pully installed...I am also getting a megasquirt 2 computer to help tune with the boost..What do you guys think i will all need to get good power from this set up...My tranny is a t5 fully built and im running a stage 2 clutch masters clutch..I have upgraded the fuel injectors already a while ago to i think 27 lb but not positive( cnat find the sheet again) should what do i need to make sure my motor wont go boom the first time i boost...Anything will help..if you need more info from me let me know..I have ALOT of bolt ons already installed on the car..
Thank you for your time
Old Feb 21, 2012 | 10:21 AM
Ronny's Avatar
Re: Procharger on semi stock 305 tpi
MS is a great system. However this needs a look as an alternative. Check out its datalogging program with VE-Learn and bin creation @ dymamicefi.com.
Old Feb 21, 2012 | 01:43 PM
utilityguy2's Avatar
I agree, dynamicefi.com is the place to go.
Old Feb 21, 2012 | 03:48 PM
Axle/Gears: 3:73
What would I need to go there for? I'm talking as far as bigger injectors or anything else.
Old Feb 21, 2012 | 03:56 PM
Ronny's Avatar
ECM Tuning. MS vs DynamicEFI. Dynamic has a lot to offer.
Old Feb 21, 2012 | 04:11 PM
Axle/Gears: 3:73
Well I already have the ms system and have been playing with it alot and ms says they can tune for boost. Also I got it cheap and it's new.i will check that place out after work
jaridjohn
Jul 8, 2024 03:49 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
