Sending unit ??
Old Feb 23, 2012 | 02:07 PM
TPI swapper's Avatar
Car: SS Monte TPI
Engine: 5.7 TPI
Transmission: 200r
Axle/Gears: 10 Bolt 3.73
Sending unit ??
On an 87 5.7 GTA TPI engine what is the sending unit in the right cylinder head between cyl's 6 & 8 ?? (oil temp. maybe ??)
I'm swapping this into an old Monte SS and I ain't got nothing on the harness to plug into it.
Much thanks.
Old Feb 24, 2012 | 08:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Sending unit ??
Usually the sender for a temp gauge.
Nothing to do with engine management harness
Oil temp sensor if ever fitted is into the oil gallery port above the oil filter
Old Feb 24, 2012 | 08:31 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Sending unit ??
Much thanks.
Sounds like the secondary fan switch. Turns on the passenger side fan. If that is it all you need to do is find a connector for it.
Old Feb 24, 2012 | 08:35 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: Sending unit ??
You could always buy the hypetech fan switch, which will come with a connector too. OR just buy the connector at an auto parts store and wire it to your own switch,then ground the other end of course. Then you have your own controllable fan switch.
tattmann
Sep 27, 2015 05:20 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
wstephan96
Sep 25, 2015 04:28 PM
6998poncho
Sep 25, 2015 02:56 PM
lanceflame44
Sep 25, 2015 12:28 PM
