First Startup After Swap - Checklist?
Old Mar 7, 2012 | 04:03 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So this weekend may be firing up the Firebird after a huge swap. What kinda things should be checked before taking it out on the road? Also how much of a easy break in period before going WOT with it?
Here is whats been done:
Swapped from a 91 L03 to a 87 L98 but with a SD harness and ECM from a 91. Rebuilt the heads, many performance upgrades. Cam, Intake work, ect...
Swapped rear from 10 bolt drum to 9 bolt disk 3:45 limited slip, new brakes
Rebuilt Trans
Complete exhaust system
Front Brakes
Added a Line lock
WS6 Wheels / New Tires
AC Deleted, A.I.R. Deleted, Cruise Control Deleted
on a side note cant seem to find the connector for the power steering idle up switch
and with deleting the ac, A.I.R., and cruise control deleted how many extra connectors should I have once everything is plugged in?
Old Mar 8, 2012 | 08:52 AM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
Re: First Startup After Swap - Checklist?
I just did a similar swap. I basically checked all fluids (engine oil, trans fluid, rear axle, coolant, brake fluid) , primed the oil pump, started the engine, timed engine, let run until fans came on, look for leaks, checked lug nuts and took it for a drive around the block. You didn't state that you made any changes to the reciprocating assembly, and with the 87 you should have a roller cam which don't require any break in period, but I'd recommend driving normal for ~100 miles.
bamaboy0323
Sep 3, 2015 06:07 AM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
