aluminum heads
Old Mar 7, 2012 | 10:57 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
aluminum heads
I have a stock 90' L98 with IRON heads. is there any aluminum heads I can put on without changing valves or anything? just bolt em on and go to reduce weight and gain a little power? dont want to spend 800$ just wondering if anything from a junkward/ parted out car would work?
Old Mar 8, 2012 | 01:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: aluminum heads
How much do you want to spend?
Only junkyard alum head are Vette L98 heads; hardly worth the trouble
Vortecs are the head of choice for cheap perf upgrade but they are cast iron so don't meet your criteria
Old Mar 8, 2012 | 02:23 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: aluminum heads
I've got an l98 too and think I'll get a set of aluminum procomp heads from skip white
Old Mar 8, 2012 | 02:24 AM
peterc005's Avatar
Transmission: T700
Re: aluminum heads
No point in reusing old valves, not worth the hassle new valves and rockers are not expensive
Old Mar 8, 2012 | 05:01 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: aluminum heads
Only way i can see you getting aluminum heads for 800 or less is a set of L98 corvette heads...which is ok but doesnt really get you THAT much farther ahead than a set of ported out stockers. If it were me i would save until you could afford a set of AFR heads or Dart pro1's. Both are in the 1200-1400 dollar range as are most aluminum heads.
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
