will this work ?
Old Mar 10, 2012 | 11:18 AM
TAG305's Avatar
Car: 87 firebird formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
will this work ?
i have a 87 305 tpi 5spd formula and im looking to do the tpi vortec and i can get a set of free 350 vortec heads but will they bolt right up to my 305 block is there any mods or fabrication that needs to be done if i did this would it have to be retimed any answers will help alot thanks
Old Mar 10, 2012 | 03:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: will this work ?
You'll need the Scoggin Dickey / Edelbrock Vortec TPI intake manifold, and a set of headers. The stock intake nor exhaust manifolds will not bolt up to those heads.
Also the 350 Vortec heads have 64cc combustion chambers, while your 305 heads have 58cc chambers, so you will lose some compression.
In my opinion, its not worth it.
Old Mar 11, 2012 | 06:57 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Yes that is going backwards. You will lose compression
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
