Which air filter to buy?
Old Mar 11, 2012 | 12:52 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Im about to buy some Summitracing products guys. I want to buy some K&N air filters but I saw that Spectra makes the very same filter for half the cost. THey are both made of cotton so whats the difference?
K&N
BrandK&NManufacturer's Part Number33-2008-1Part TypeAir Filter ElementsProduct LineK&N Washable Lifetime Performance Air FiltersSummit Racing Part NumberKNN-33-2008-1UPC024844090140Air Filter StylePanelLength (in)6.625 in.Width (in)6.625 in.Height (in)1.625 in.Filter MaterialCotton gauzeFilter ColorRedQuantitySold individually.
Spectra (as an attachment)
BrandSpectre PerformanceManufacturer's Part NumberHPR3915Part TypeAir Filter ElementsProduct LineSpectre Performance hpR Air FiltersSummit Racing Part NumberSPE-HPR3915UPC089601004167Air Filter StylePanelLength (in)6.690 in.Width (in)6.690 in.Height (in)1.260 in.Filter MaterialCotton gauzeFilter ColorRedQuantitySold individually.
Old Mar 11, 2012 | 12:55 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
Re: Which air filter to buy?
same thing....your paying for the name, with the k&n stuff.
Old Mar 11, 2012 | 01:02 AM
Right on man. Thanks.
Old Mar 11, 2012 | 09:08 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I run the cheap paper filters in mine. The car runs the exact same times with them in or out.
Old Mar 11, 2012 | 10:54 AM
actually, if your car is a MAF system, you run the risk of contaminating the MAF with the filter charge oil that most cotton filters need. oe paper is fine too.
Old Mar 11, 2012 | 11:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The K&N filters will has longer then the car with the correct Maintenance (that means follow the instructions and DO NOT over oil). Bought mine in 1988 and still using the same filters (again proper maintenace).
Old Mar 11, 2012 | 07:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I run the cheap paper filters too. Fram from Walmart.
Old Mar 11, 2012 | 09:15 PM
Love the input guys. I never thought about the fact that the cleaning/charger oil can contaminate the MAF Sensor. I might just stick the the paper filter then.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
theurge
Aug 21, 2015 12:46 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
