Help needed with external coil (buying a new one)
Old Mar 14, 2012 | 05:48 PM
Trinten's Avatar
Car: Daily: Lincoln Town Car.
Engine: 355 SBC in the Fiero
Transmission: 5 speed F23 w/LSD
So I've got a f-body small diameter distributor as part of my swap from carb to EFI, and need to get a new external coil for it.
I've done some reading and it seems that these "e-core" ignition modules are really good... however the ones I've looked at on Summit have a similar appearance to the in-cap coils (and the description does not say if it's in-cap or not).
Anyone know any definitive parts numbers for a performance/upgraded external coil? Just want to make sure I'm getting the right thing.
Thank you!
Old Mar 17, 2012 | 07:36 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Help needed with external coil (buying a new one)
http://www.summitracing.com/parts/SUM-850012/
Old Mar 17, 2012 | 07:51 PM
Trinten's Avatar
Awesome! Thank you very much!! For some reason I thought they were just wacky in-coil ones.
Old Mar 17, 2012 | 07:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
( does not say if it's in-cap or not).
Must be looking at the wrong ones.
Factory small cap coil is as linked above ; has provision for the two factory harness plugs .
Coil in cap style coil has 3 wires
Note
you only need the OEM style coil if using OEM small cap connectors on harness.
Can use any suitable coil if you change terminations
Old Mar 17, 2012 | 07:54 PM
Trinten's Avatar
Thanks for the extra info Vetteoz.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
L98GTA87
Aug 5, 2015 11:02 PM
