Get more power out of my 305 tpi
Old Feb 14, 2012 | 07:33 AM
Mont21's Avatar
Car: 86 Trans Am
Engine: 305 Tpi
I have a 86 trans am 305 tpi.. Factory everything.. I want to get more house power out of the car what car I start doing to it? I heard headers, cold air intake. But I'm not sure what should I do?
Old Feb 14, 2012 | 01:04 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: Get more power out of my 305 tpi
Yes both of those will do something. That's the 1st thing I did with mine. Then I updated my rear end with a 3.73 gears and that helped big time.
Next was a cam and intake swap.
I'm pretty happy with how it runs...Until I can build a replacement lol!
Old Feb 14, 2012 | 09:38 PM
Mont21's Avatar
Car: 86 Trans Am
Engine: 305 Tpi
So.. Tell me the first step.. Im at factory.. Im not tryin to spend alot of money maybe 500 every two weeks.. Wat is the first thing I should do? Im all factory now..
Old Feb 15, 2012 | 07:07 AM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
More air in....more air out.
Air intake and headers / exhaust
Old Feb 15, 2012 | 07:45 AM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
1. Cat back exhaust $200 to $300
2. Headers $300 to $500
3. 3.73 gears $750 installed
4. Cam for a flat tappet motor like yours $100, install is a huge job.
http://www.summitracing.com/parts/SUM-G5000/
Cam kit is no longer available but you can purchase just the cam for $50 http://www.summitracing.com/parts/SUM-1102/
A solid 40hp with the cam.
Old Feb 15, 2012 | 08:16 AM
Mont21's Avatar
Car: 86 Trans Am
Engine: 305 Tpi
What would u perfer.. rememba this is goin to be a summer car but everyday driver.. shorty headers and what catback do u perfer?? And where can I get the k&n filter kit I been lookin everywhere
Old Feb 15, 2012 | 08:37 AM
burnout88's Avatar
Car: 88 IROC
Dyno Don makes the best headers for thirdgens right now. But they are more expensive. If you cannot get those then try out the headmen headers.
Old Feb 15, 2012 | 07:11 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
My advice is to buy only stainless steel exhaust, because anything else won't last.
I also suggest 1.75" primary shorty headers. It's not ideally sized for a 305, but are more valuable for re-sale or use on an upgraded engine in the future, thus you only buy them once.
There is a lot of power to be gained with a complete exhaust upgrade, but stainless isn't cheap, and working with exhaust isn't easy. It may take a couple of months to pay for the good stuff but will be worth it in performance and longevity.
Old Feb 15, 2012 | 07:53 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
All you need is Dyno Don's headers(he's on TGO in the SoCal board) and a Magnaflow cat back system. Do not change the gears because with a stock TPI it will be too much and you will lose top end and gas mileage. 3.23's are the best gears to have. Beside the engine doesn't breathe pass 4800rpm.
Old Feb 15, 2012 | 09:01 PM
burnout88's Avatar
Car: 88 IROC
My 3.73 gears are perfect for my 305. 3.23's are a big disappointment. I shaved over .7 tenths in the quarter mile with my 3.73's and I never even notice them and still great mpg's.
Ask anyone on this board with 3.73's and they will tell you there are no regrets with them.
Old Feb 18, 2012 | 08:45 PM
dem74's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8
Transmission: 700r4 with TransGo shift kit.
Axle/Gears: 3.73 with locker
I also run 3.73 gears in my 88 GTA. Zero regrets, it's the perfect gear!
Old Feb 22, 2012 | 02:15 PM
zeeboid's Avatar
Car: Cadillac CTS-V Wagon 6sp
Engine: 6.2SC
Transmission: 6 speed manual
What did you have to do after installing the 3.73 to get your speedo to read correctly?
Old Feb 22, 2012 | 02:37 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
I agree exhausts and headers do wounders. I was using a 305 for a bit and it would pull like a mother with just exhaust. My buddy said that it didn't pull that much when he had it in his stock 92
Old Feb 22, 2012 | 03:39 PM
dem74's Avatar
Engine: 5.7L V8
This is the site that I used to determine what gear I needed to correct the speedo. http://www.transmissioncenter.net/sp...__va.htm#700r4
Good luck!
Old Mar 14, 2012 | 12:01 PM
boxfrogman's Avatar
Car: '85 iroc z28 camaro
Engine: 305 v8
Transmission: a4
Axle/Gears: ?
I have an 85 iroc z28. I am wondering what i can do to get more low end torque and power out of it, while keeping my gas mileage within in the same area. It is completely stock. 305 v8 with tuned port injection. puts out about 200 ish horsepower. I am not sure how much because I have not taken it to a Dyno.
Old Mar 17, 2012 | 09:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
See my sig.
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
