sounds like a massive Vacuum leak, running terrible
Old Mar 15, 2012 | 06:02 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
Just got the camaro back together. Has not been driven in almost 6 years. It is a 1989 350 TPI, stock intake/throttle body. Only mod is the airfoil between the butterflies on the throttle body. When it runs, badly, it has a massive sucking sound right at the lower hole on the airfoil. Is that normal? Even with the airbox lid on, and locked down, 25 feet away you can hear what sounds like a massive vacuum leak at idle. Car stumbles, and runs bad. it has been so long since I drove it, I can't remember if that noise was normal. Any help would be great. Thanks in advance
Old Mar 15, 2012 | 08:29 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: sounds like a massive Vacuum leak, running terrible
It could be that you have a bad IAC valve that is not closing.
I would pull the IAC and check it out closely.
Old Mar 15, 2012 | 08:51 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Thats normall for a TPI to make a sucking sound from the TB. What codes do you have?
Old Mar 16, 2012 | 02:11 PM
89rsvert's Avatar
Thank you guys. I did end up checking the IAC, and it was
pretty carboned up, so I cleaned it up. Seems
to be a little quieter now. Didn't run any better. After a little
more research, I found the 1,3,5,7 injectors were not getting
power. After changing the fuse, I now have all 8 cylinders up
and running.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
mustangman65_79
Aug 8, 2015 12:07 PM
