how to make more power!!
Old Mar 16, 2012 | 07:30 PM
raceace18's Avatar
Car: 1989 gta
Engine: 5.7 350
Transmission: borg wagner 5speed
Axle/Gears: 327
HEY!! 3RDGEN. i have a 89 gta l98motor.
1.l98block stock pistons,stock crank, all stock fresh rebuild. 3000k on rebuild
2.vortec heads with stock valve train. aluminum heads.
3.hsr intake manifold, lt1 stock cam. svo 24lbs injectors.
4.msd ingnition, accel super street wires, mallory dizzy.
5.327 rear, with a t5 tranny.
it also have a mail order tune. but its not enough!!
i was wondering if i retune with a different tune and some dyno time.
will i be able to make close to 300rwhp?? i am a noob to the f-body scene.
any help oe advice would be helpfull..
Old Mar 17, 2012 | 08:01 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: how to make more power!!
I'm a little confused: Vortecs or aluminum heads? Anyways, a real time tune is worth it's weight in gold. There are folks out there can that come real close just by a good description but there's no substitute for data logging.
BTW, I believe 300 RWHP is easily reachable w/that basic set up.
Old Mar 18, 2012 | 04:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
how much hp do u have now? You should already be there or close.
Old Mar 18, 2012 | 04:08 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
might have the 300hp but that t5 will hate you..... its on borrowed time my friend...
Old Mar 18, 2012 | 08:01 PM
raceace18's Avatar
Car: 1989 gta
Engine: 5.7 350
Axle/Gears: 327
cam lift is 440 and vortec steel heads
Old Mar 18, 2012 | 10:01 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
You definitely are right around 300hp at the crank. If you want more power you need a bigger cam, and with those Vortecs you are going to half to mod them to accept more lift. Or if you don't want to break into the engine, Nitrous or a Super Charger is the way to go.
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
