help with stalling
Old Mar 23, 2012 | 05:58 AM
trojjan's Avatar
help with stalling
I hvae read all the threads I can find about this problem and it hasn't solved my issue.
I have an 86 305 TPI swapped into a 64 C10. New injectors, all new sensors except MAF, new throtlle body, new regulator , new fuel pump and filtere, Hansen chip in ECU, headers with heated o2,etc etc.
Truck starts and runs great. Once it is warmed up and I am coming to a stop it will always stall. Starts right back up and runs fine.I have noticed that just before ,or as it stalls the tach needle with jump up a bit.
Any help would be appreciated.
Old Mar 23, 2012 | 09:47 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: help with stalling
sounds like you never installed a vss
Old Mar 23, 2012 | 09:50 AM
Engine: Lb9
Transmission: M20
http://www.tpiparts.net/inc/sdetail/7586
Old Mar 23, 2012 | 10:49 AM
trojjan's Avatar
You are correct I do not have a VSS.The wiring harness I used instructed me to ground circiut 437 on the ECU and I wouldn't need a VSS???
Can you comment please.
Old Mar 23, 2012 | 11:35 AM
Engine: Lb9
Transmission: M20
You don't say if this is maf or map, assuming that you grounded the p/n switch pin B10 on a 1227165 ecm the ecm thinks its in park or neutral and adds to the idle speed. You stated your running a hansen chip in the ecm. I have no idea what that is and if its based on stock gm programing 32, 32b or 6E. Since the ecm never sees that you are moving coming to a stop the ecm does not know the vehicle is moving and the sudden slowdown will cause a rpm to drop and may cause a stall. Install a vehicle speed sensor.
Old Mar 23, 2012 | 11:56 AM
trojjan's Avatar
Thanks for the help. The swap the stock MAF sensor.I will install VSS as soon as I can figure how to install one. The speedo cable is a direct bolt in on the trans (T5) so I have to figure out if I can install the recommended VSS conversion up at the speedometer end.
Thanks again
Old Mar 23, 2012 | 08:43 PM
Engine: Lb9
Transmission: M20
not sure how you installed your fuel system but if it was a cavitation it would be noticed on hard cornering or hard take off. the vss needs to go to a buffer than optical out to the ecm. I have a buffer but no harness they can be found on ebay.
http://www.ebay.com/itm/VSS-Vehicle-...ef398a&vxp=mtr
Old Mar 23, 2012 | 09:16 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I had this same problem and it was a bad MAF sensor.
Old Mar 27, 2012 | 05:42 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Other possible solutions if stalling occurs after installing a VSS. This is straight out of my 86 GM Camaro Shop Manual
Old Mar 28, 2012 | 06:09 PM
trojjan's Avatar
I appreciate the input but I am dealing with a situation that sees the engine die when rolling to a stop not a hesitaion or stumble.
Old Mar 28, 2012 | 06:37 PM
From my experience, I had the same issue too. So what I did was switch out a few things and the problem went away. The things I did was replace MAF Sensor, installed a speedo cable (never had one), and I noticed that my Idle Air Control Valve had backed out and was creating a vacuum leak. After replacing, installing and retightening the valve, my iroc never died when I let off the pedal.
Old Mar 28, 2012 | 08:09 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I had the exact same problem and it was the MAF.
Old Mar 30, 2012 | 05:14 PM
trojjan's Avatar
Well a bunch of cash and effort to install a VSS in my truck.
Got it all completed and I still have stalling issues. I am beginning to think that the TPI install was a mistake! Don't know what to do next.
Old Mar 31, 2012 | 12:26 AM
Check the IAC Valve. May be loose and creating a vacuum leak. Also you may want to remove the IAC and clean the port and needle with carb cleaner spray. When You reinstall the IAC, pull back the spring and turn the needle so that it screws into the motor. If its too far out, you can damage the IAC motor when you screw it in with the needle all the way out.
Old Mar 31, 2012 | 06:15 AM
trojjan's Avatar
Thanks for the input. I have done exactly that twice...once with a new IAC. I have read every thread and tried everything suggested except replacing the ECU and still no results.
TPS, IAC, BOTH TEMP SENSOR, MAF, COIL, DIST, RELAYS WERE NEW, THROTTLE BODY WAS NEW,ETC ETC
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
