Relocating Egr
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Relocating Egr
Was reading the article http://www.popularhotrodding.com/tec...ls1/index.html
They talk about using the v6 camaro egr set up and was wondering if anybody did it before ?
I search this forum and couldn't find anything
Only interested because I would like to maintain egr set up
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: Relocating Egr
what injection setup/ computer system? im gonna be using ob2 so i used the remote mount 3.8/ 3.4 v6 style. older system u would use the v6 2.8 remote mount style.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
I'm planning to swap a lt1 intake on my tpi and have to block off the egr on lt1 intake and using stock computer
Car: 91 formula ws6
Transmission: 4l60E
Re: Relocating Egr
i would think the 2.8 remote mount would work. go to a junk yard and look for one and go from there.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Yea I look it up it's mounted to exhaust headers and another tube goes from egr to intake I'm wondering how can I m suppose to set it up for lt1 intake I know I would have to weld tube to intake then egr but how will I route it to the intake
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Relocating Egr
Why not use the TPIS Miniram EGR set up? That what in doing with my Miniram.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Would love to get the miniram put that's going to set me back 1500 at least egr is about 280 miniram 895 and fuel rail is about 200 sum thing I'm saving up for that but for now I can go to junk yard and get cheap lt1 intake or on eBay for about 60-80 $ and prob put in no more than 150 in to it most of it I'm doing myself the intake is wats holding my engine back right now
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
I got my Miniram for free with everything except the EGR. They are selling for cheap on eBay.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Wow you lucky how you manage that
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Comp cam 8-501-8
Duration at .050" lift: 212 int./218 exh.
Valve lift with 1.5 ratio: 0.488 int./0.495 exh. lift
Headers full exhaust
Trans shift kit
3.42
Next upgrades are 1.6 rockers And springs upgrade
Of course intake upgrade
Tq converter 2400 stall
Then heads if needed but that's down the line
Hoping to get over 300 whp
Trans shift kit
3.42
Re: Relocating Egr
It's ok far but it's needs more tuning. Right now I have the heads off for major porting. When I get it back running it should make around 425-435whp @ 6400
Engine: 305 to 350
Axle/Gears: 10 Bolt
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
You running lean at higher rpm ?
Car: 91 formula ws6
Transmission: 4l60E
Re: Relocating Egr
now thats a score on the miniram. i didnt know the miniram had a separate mount egr? can you post a pic? lol. i may snap some pics this week when i work on my motor. its at work 20 miles away.. may be interesting to snap pics of all the remote mount egr set ups for folks like us that wanna stay emissions compliant.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
What intake your running that would be such a great amount of help there's only like on tread but it isnt complete yea go to tpis website they sell it there egr setup for miniram .. I know it's possible to mount one
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Relocating Egr
Wow that's no good at least its better than being to lean that would be bad day
