Has anyone made a cereal box gasket for the TPI Runners?
Old Mar 31, 2012 | 12:28 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
So is it a good idea or a bad idea? Just had a sweet Port and Polish done to my SLP runners but I would love to have more material on my runner gaskets. The SLP gaskets are too thin (not wide enough).
Old Mar 31, 2012 | 06:39 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Has anyone made a cereal box gasket for the TPI Runners?
Make-you-own gasket material comes in various thicknesses. I've used a cereal box to partially block a rad in the winter months, but I don't like the shiny side of the box for use as a gasket.
Old Mar 31, 2012 | 09:44 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Gasket paper is a special blend of materials designed to compress just enough and hold up under pressure. I don't know if the cheap cardboard used for a cereal box will do the same. Definitely invest in gasket paper.
Old Mar 31, 2012 | 09:50 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Mr. Gasket #146
They are 1.800
Old Mar 31, 2012 | 10:33 AM
Cool. Thank you ASE Doc and Dyno Don. :-)
Old Apr 3, 2012 | 10:33 AM
Crudsturbo's Avatar
True story here, I used a cereal box for a gasket on an 89 Cadillac water pump. With that being said a lot of silicone was used. And it wasn't my car the guy who owned it let a crackhead change it and this guy had his subframe unbolted, radiator out, and half of the pieces on the fender wall removed. When I put it back together the auto part store wasnt open and he couldnt wait another day so he begged me to make it out of a cereal box.
Note this guy came to me I told him $200 labor for the job and he said too much. This guy told him $45 dollars and he ended up paying me $300 to fix it. Do your car right the first time saves so much money. While cereal box is usable I don't trust it you can buy different forms of gasket paper very cheap or for a decent price. But still cheaper than a premade.
I forget who sells it but we use it at the car wash its a gasket you with a mild adhesive you set it on what you want and tap it with a hammer( a very small one) and it froms the gasket and is super easy to cut. Best stuff ever made!
Old Apr 23, 2012 | 12:53 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
i made lt1 water pump gaskets out of them before since local parts stores didnt stock them at the time
Old Apr 23, 2012 | 01:11 AM
did it last?
Old Apr 23, 2012 | 02:01 AM
Car: 1991 camaro RS
25k miles so far on them lol no leaks
i would think that since the tpi plenum gaskets are much thicker in general i wouldnt but
then again the stock gaskets are dry flow and been useing the factory gaskets still for tpi i would reuse them unless one is ripped
Old Apr 23, 2012 | 09:35 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Based on how many times I've re-used the same TPI gaskets over and over again, I'm pretty sure that you can make them out of pretty much anything. It's probably been 10 years since I've bought any TPI gaskets, and in that time I've had my plenum & runners off the IROC a dozen times and had them off the Corvette at least twice. The fact that it's a dry environment (aside from minimal PCV material) makes it pretty easy on the gaskets.
Old Apr 23, 2012 | 09:06 PM
Abubaca's Avatar
LOL, I'm with Jim, I've had the same set of gaskets since I bought the car!!!!! ....that being said, I don't know that I'd use a cereal box when new oversized runner gaskets are so cheap.
Terrell351
Jun 13, 2021 01:13 PM
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
