unplugging MAF
Old Mar 31, 2012 | 10:00 PM
ROCmy86's Avatar
Car: 86 IROC
Engine: 355 Stealth Ram
unplugging MAF
if i unplug my maf will the computer run in speed density successfully?
Old Mar 31, 2012 | 10:05 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: unplugging MAF
No, it will throw some codes at the computer and probably not run right, you wiring harness and computer is set up for MAF. You will need to change your harness and re tune your computer to run on speed density. You will need the harness out of a 91-92 TPI and the computer. MAF is a completely different system than Speed Density
Old Mar 31, 2012 | 10:21 PM
ROCmy86's Avatar
Car: 86 IROC
Re: unplugging MAF
ok thanks for the info
Old Mar 31, 2012 | 10:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: unplugging MAF
Old Mar 31, 2012 | 10:49 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Re: unplugging MAF
No problem
Old Apr 2, 2012 | 02:40 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Re: unplugging MAF
Old Apr 2, 2012 | 09:13 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Re: unplugging MAF
yeah it'll just throw codes and run bad.
Old Apr 2, 2012 | 09:22 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: unplugging MAF
I have to run with mine disconnected, or the car will stall out. I am going to get a new MAF, but it does not run bad unplugged. I read on another thread that it won't hurt anything and a lot of guys are running with the dicconnected. Hmmmm
Old Apr 7, 2012 | 07:37 PM
camarorookie's Avatar
Re: unplugging MAF
With the MAF unplugged the ECM uses the fuel tables to adjust fuel mixture. If you have a good tune it should run fine with it unplugged, but it will run either lean or rich so it is not recommended to run without it for long. I ran mine for two weeks with it unplugged and actually got better gas mileage, but performance and response was down.
Old Jun 2, 2012 | 07:41 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Re: unplugging MAF
Originally Posted by camarosrock1989
I have to run with mine disconnected, or the car will stall out. I am going to get a new MAF, but it does not run bad unplugged. I read on another threat that it won't hurt anything and a lot of guys are running with the dicconnected. Hmmmm
Did you get a new maf yet?? Mine is actin the same way, was thinking of replacing my maf?! Thanks for any info!
Old Jun 3, 2012 | 03:17 PM
Engine: MPFI
Re: unplugging MAF
Irockid I have not replaced it yet, it runs great. No problems yet. I will be replacing it, just hope when i do that the after market one will work as good as factory one's.
I have heard that they don't.
Old Jun 3, 2012 | 05:27 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: unplugging MAF
Id go with a direct Bosch replacement. And, avoid remanufactured ones. Ive had back luck numerous times with remanufactured Bosch sensors. Running the car long-term with the MAF unplugged is unhealthy and, I for one don't reccomend it. Short-term, yes.. get to work or grab groceries.
Old Jun 3, 2012 | 07:43 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Re: unplugging MAF
Thanks for the feedback. I recently purchased a reman Bosch at napa. It doesn't seem to be working properly. It's still under warranty, hopefully it's replacement works better. I'll let you know how I make out.
Old Jun 3, 2012 | 08:06 PM
Engine: MPFI
Re: unplugging MAF
I would like to hear back, curious if you get a better one. So can you buy a new bosch? Instead of a reman? What did you have to pay for it?
Old Jun 4, 2012 | 02:55 PM
irockid43's Avatar
Car: 86 IROC-Z
Engine: 355
Re: unplugging MAF
I just installed the bosch maf I got from napa with another one... and it runs much better!!! No codes, better throttle response than when it was unplugged, seems great! This project has been frustrating, i think Ive got all the bugs worked out. Thanks for the replies and good luck! Keep posting with your results.
Old Jun 10, 2012 | 01:40 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: unplugging MAF
new replacement MAF sensor is simply not to be had,and re man ones ,im finding.last on average 6 months
Mark_ZZ3
May 24, 2018 01:02 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
racereese
Oct 3, 2015 03:46 PM
