Air Foils: Are they worth a damn?
Car: 86 IROC
Engine: 355 Stealth Ram
Hey im new to the camaro scene, i had a question about air foils ive seen these on web sites such as summit and i was wondering are they worth the money. do they increase hp or trq? I have a feeling they must do something if summit is selling them and i see them on a few mod lists on the forum. Any info would be great.
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Air Foils: Are they worth a damn?
There's a lot of pro vs con regarding them on this forum. In the search box type 'air foil' and you'll see a lot of discussion about them.
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
Summit also sells these jokes, so I wouldn't put too much weight on that...
http://www.summitracing.com/search/B...eyword=tornado
I think if you're looking for that last 1% of power, maybe something like the airfoil may be worth it. However, I think money spent elsewhere is a better bet. My only similar experience (which was eye opening for me) was on a dyno. LT1 with a TPI "Y" intake. I had one lower part complete with rain guards and another lower part that had that portion removed. Theory said there should be a difference in power, but on the dyno, not a lick of difference between the two (~272hp).
Engine: 4++,350 & 305 CIs
Not worth it..
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
On stock throttle bodies the air foil will reduce turbulence at high throttle openings. How effective is this? I don't know. I certainly would be reluctant to buy into the claims made by some manufactures. Then again, if Myron Cottrel of TPIS thought it worthwhile to make one, Id at least give it a look.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
