Difference between F-body and Vette EGR valve?
Old Apr 6, 2012 | 09:08 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Does anyone know if there is a difference between the F-body and Vette EGR valves? I'm not talking about the EGR system, only the valve itself. I know there is a difference in the systems as far as where it gets exhaust gases. In photos the valves look nearly identical but have different part numbers. I'm looking to put one onto a Corvette TPI manifiold, but since my heads do have an exhaust crossover, I plan on simply blocking off the port that would normally connect to the #8 exhaust, and getting exhaust to the valve from the head.
I'm pretty much needing to know if the vette one will work the same as the F-body one since the vette one is $20 cheaper and in stock at my local parts store and the F-body one is more money and needs to be ordered.
Out-Cast
Sep 3, 2015 09:05 PM
Out-Cast
Aug 17, 2015 10:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
