help choosing a head gasket
Old Apr 7, 2012 | 10:02 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
I'll straight up admit I'm way out of my league and this is all a bit daunting. I'm reading up from articles on the net but thought I'd check in for some actual hot-rodders experience
I've got a '90 L98 GTA and have purchased some AFR 180CC 919 heads and the xfi268 comp cam. Block is standard. It's a speed density car
Grateful if someone could guide me about what head gasket I'll need for decent drivability compression.
Don't think it matters but car will have a heavily ported TPI setup (siamesed runners), 25 lb injectors and a 52mm TB.
If you need anymore info, let me know
thanks
Old Apr 7, 2012 | 03:45 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: help choosing a head gasket
Call GM an order a Hi Performance head gasket for an 87-91 Corvette which is .028 thickness. It will boost the compression. If they don't have it then call TPIS. Dont use Fel-Pro.
Old Apr 7, 2012 | 07:05 PM
GTA1990's Avatar
Car: 1991 Trans Am
thanks man - appreciate you chiming in. Been trolling the TPI boards recently and yours and other cali members' whp numbers have kept me tpi.
found the gasket on summit's site:
http://www.summitracing.com/parts/NAL-10105117/
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
