TPI HELP!
Old Apr 16, 2012 | 11:17 PM
Schaef89Iroc5.7's Avatar
Car: 1989 Iroc Z 5.7L
Axle/Gears: 9 bolt 2.77 (original) 10 bolt 3.42
TPI HELP!
I have an 89 5.7l car that was running great and now barely runs at all. It will start and run extremely rough. If I shut it off, it will not sputter or start. Wen it does run, It is extremely rich and also it throws no codes. Any advice?
Old Apr 16, 2012 | 11:19 PM
Re: TPI HELP!
The car has a brand new fuel pump, distributer, coil, egr valve, plugs
Old Apr 16, 2012 | 11:52 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
Re: TPI HELP!
My 85 Cadillac DeVille did that. Was running great one minute and the next minute it was almost dead. I had to nurse it home 20 miles. Turned out to be the ECM went bad. Hope your Ecm is ok.
Old Apr 17, 2012 | 07:50 AM
Re: TPI HELP!
mcsslover1987, Thanks for the reply. Is there an easy way to test the ecm in that car? I did install a hypertech chip in the computer years ago. Could that be faulty? This is the one area i'm not real useful in. I checked the resistance in my tps and iac and they are both functioning properly with a voltmeter. I replaced the distributor because it was original. I changed the coil to an MSD. I was going to pull the plug wires and check them for ohms. I did a bunch of research last night and I keep going back to maybe the ECM being bad, never mentioned it in my thread, and you brought it up as well. I drove the car one day to work last year to work and got it inspected. When they finished the inspection, I went to start it and it cranked but got nothing. It finally started later that day. It was breaking up and then dies about a mile down the road. I had to trailer it home. Been goofing around with it ever since. I have no Service light on while it runs and no codes. I've had this car for 12 years and never had a problem. I did replace other items... Fuel pump, plugs, intake temp sensor,etc. If I let the car sit, It will eventually start but runs rough and misses. If I shut it off and try to restart, it will just crank over with the starter. Any replies much appreciated!
Old Apr 17, 2012 | 07:53 AM
Re: TPI HELP!
Just to add.. I drive this car about 1000-2000 miles per year. It has 84k on it and sits in a steel building with a concrete floor. In absolutely awesome condition.
Old Apr 17, 2012 | 01:57 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: TPI HELP!
Did you check the fuel pump relay and the injectors?
Old Apr 17, 2012 | 02:33 PM
Re: TPI HELP!
Mongoose, thanks for your reply! I did actually replace the fuel pump relay and I'm glad you brought that up. I pulled the car outside the one time and let it run for about twenty minutes. When I pulled it in, I shut it off but the fuel pump kept on running. I had to pull the battery cable. After reconnecting the cable a couple hours later, it was fine. I still replaced the relay thinking maybe that was my issue but it happened one other time after that. It seemed to happen when it was damp out. I did pull the injectors and they all did spray and none of them seemed to be leaking.
Old Apr 17, 2012 | 04:24 PM
southbay08's Avatar
Re: TPI HELP!
you might want to check the ohm on the injectors when they are cold and hot.
Old Apr 17, 2012 | 04:36 PM
Re: TPI HELP!
what should they be when cold and when hot?
Old Apr 17, 2012 | 04:49 PM
southbay08's Avatar
Re: TPI HELP!
Anything less than 12ohm should be replaced...indicative of coil failure. The coils
on the injectors cannot be repaired.
Old Apr 17, 2012 | 07:09 PM
Re: TPI HELP!
ok. I will check them and get back to you!
Old Apr 17, 2012 | 11:55 PM
Re: TPI HELP!
Finally! I feel kind of ignorant, but I have learned so much from all of you. I did a cold ohm check on my injectors and finally think i got results I'm looking for. #1 16ohms #2 2ohms #3 14ohms #4 13ohms #5 12ohms #6 16ohms #7 14ohms #8 14ohms. I had to check #2 5 times because I didn't believe I got the results but was consistently 2 ohms. Southba08, We need to talk about injectors don't we?
Old Apr 18, 2012 | 12:06 AM
Mongoose's Avatar
Car: 90 Formula
Re: TPI HELP!
Sounds like my situation after my TPI swap...3 of my injectors turned out to be bad so in went a set of Bosch 3 injectors and no problems since.
Old Apr 18, 2012 | 12:50 AM
weaselbeak's Avatar
Re: TPI HELP!
I put a set of Bosch III's that had been rebuilt by John at FIC in my c4. I had a noticable improvement and consider it money well spent.
Old Apr 18, 2012 | 06:31 AM
Re: TPI HELP!
It is nice to have some direction for a change. Could have sworn that I tested these things before but must not have had the ohm setting right. This time I went to the lowest setting and it read perfectly. I have about $350 into this thing already but consider it money well spent because it is all maintenance items in a way. I did find some faulty and worn out parts along the way. I'm not crazy after all! I will get injectors and repost after install.
Old Apr 18, 2012 | 06:42 AM
southbay08's Avatar
Re: TPI HELP!
Yup, sorry to say but your injectors are "shot"
Give us a call when you are ready and we will be sure to take care of you.
Happy you found the problem
Old Apr 18, 2012 | 07:03 AM
Re: TPI HELP!
Soutbay08, I will be getting in touch with you this morning. I'm actually in Western New York and if there is any way I could get these injectors by friday, I would be ever so greatful. It would be fantastic to put an end to my woes with this by the weekend! Talk to you soon!
Old Apr 18, 2012 | 07:13 AM
southbay08's Avatar
Re: TPI HELP!
No problem, we will get them out for you today and you will have them by tomorrow
Old Apr 18, 2012 | 01:12 PM
Re: TPI HELP!
Thanks again SouthBay08 for all your help! You can email me that info at michael.schaefer.ms@gmail.com
Old Apr 18, 2012 | 01:20 PM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Re: TPI HELP!
That exact problem happened to my Z28 last year, my injectors were reading just like yours. New set and you're good to go.
Old Apr 18, 2012 | 01:28 PM
southbay08's Avatar
Re: TPI HELP!
You are very welcome Mike! Just sent the info
Thanks again for the purchase.
Old Apr 18, 2012 | 08:34 PM
Re: TPI HELP!
I'm really appreciating all the support. I can't wait for the mail on friday!
Old Apr 20, 2012 | 11:13 PM
Re: TPI HELP!
Installed 8 brand new 22lb Bosch injectors and the problem is solved! Car runs excellent once again. Hit it with the timing light and a quick oil change and away we go! THank you again to everyone who lent me a helping hand especially South Bay! Couldn't have been so successful so quickly without all your help
Old Apr 23, 2012 | 05:01 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: TPI HELP!
was going to say ohm out the injectors thats normaly the case
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
