Will these injectors work for me?
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I saw these on eBay http://www.ebay.com/itm/19lb-Fuel-In...1e518#ht__1038 they look just like mine and I know they are 19lb but they don't say that fit. Someone help
Car: 91 Trans AM
Re: Will these injectors work for me?
Those look like Bosch gen ii yellow tops. Yes they will fit your car.I currently have a set in my 91.
Car: 1990 Camaro RS
Axle/Gears: Posi
thanks guys i figured they would but the application on ebay said no, so i had to check
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Aren't 19lb Ford injectors more like a 21lb injector at 43lb fuel pressure?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I would get the bosch 3 19#hr from southbay !!! If your bold enough to put those ebay ones in your car at least ask them what the ohm out at cold and hot !
Car: 1990 Camaro RS
Axle/Gears: Posi
I'd like to find out because they are at a good price but I have to make sure they run at 19lbs, I don't really need new injectors that's why I'm looking at these because the price is right
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
