Heated O2 Sensor Installation
Old Apr 20, 2012 | 06:02 AM
Linson's Avatar
COTM Editor (Retired)
Car: 89 Formula 350, TTA
Where is the best place to hook up the 12V wire when installing a heated O2 sensor?
-OR-
Where did you guys hook up the 12V wire when installing your heated O2 sensor?
Old Apr 20, 2012 | 06:17 AM
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
Re: Heated O2 Sensor Installation
I hooked mine into the fuel pump power wir on the switched side of the relay up on the firewall. works great.
Old Apr 20, 2012 | 07:24 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
-OR-
On my 89 I ran a fused wire off of the IGN terminal (out of the fuse box) and down to a 2 pin weather pack connector for power and ground.
I hooked the other side of the connector to the 02sensor power and ground.
I clipped the old 02 the signal wire connecter off and put it on the new heated 02 signal wire so that can be hooked back into the factory harness just like stock.
I hope that makes sense..
Old Apr 20, 2012 | 07:49 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Same here. You can grab the power from the fuel pump relay feed wire, and stick the ground wire on one of the screws that holds the relay bracket to the firewall. It's close to where the stock O2 wire ties into the harness, so you can run them all together and stick some loom on it to make it completely disappear.
Old Oct 11, 2012 | 03:29 PM
marballfire's Avatar
Car: 88 Camaro SC
Axle/Gears: 3.42 POSI
I'm about to do this install tomorrow and am having a tough time finding the right wire to tap into. In other threads I read about a pink/black wire, but in my wire loom there are 3 different pink/black wires and the only end I can find goes into the EST module. Any suggestions?
Old Oct 11, 2012 | 09:44 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Have you done a good search yet? There are a few threads that have the information you are looking for.
Old Oct 12, 2012 | 12:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Any suggestions?
Like said above ,
the switched side of the pump relay which in the typical F-body pump wiring diagram shown below would be the
tan / white wire out of the pump relay connector (running to the pump )
Could also connect to switched side of the pump oil pressure switch , same difference
Old Oct 12, 2012 | 09:34 AM
Car: 88 Camaro SC
Did do a search, but the wording made it seem as though there should have been a pink/black wire in on my fuel pump relay...there is not, hence my question.
Ended up doing as TTOP 350 did and ran the power wire straight into an empty IGN slot in the fuse box. Thanks for the help anyway, vetteoz.
Old Dec 14, 2020 | 12:09 PM
Armored91Camaro's Avatar
Car: 1992 Camaro RS Heritage Edition
Engine: LO3 305 5.0L v8
Axle/Gears: 10 Bolt Factory 2.73 Open
Here is a link to how i wired my heated O2 4-wire sensor. I used my fan relay's 12v ignition switch wire.
https://www.thirdgen.org/forums/tech...02-sensor.html
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
