Vacuum Leak Throttle Body Area
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Seems like I have a very very small vacuum leak in the throttle body area. I can hear a slight whistle and seems like it runs just a tiny bit rough at idle.
I sprayed carb cleaner around the area hoping to find it. no change
then i used a smoke machine and the only place smoke was coming out of wasaround the TPS and around where the coil spring is on the other side of the throttle body where the cables hook in.
So i guess i have 3 questions.
1. are those leaks normal? if not are there seals or orings behind that stuff?
2. Even if those area are not normal to leak since it is a speed density car shouldnt that not matter because it is before the plenum?
3. Is there anything in that area that is prone to leaks?
thanks
thanks
Engine: 4++,350 & 305 CIs
Re: Vacuum Leak Throttle Body Area
Prolly the Vbelt drive setup...
sorry I just gotta...
Sounds like the throttle shaft hole is worn a bit. Not a massive deal unless your a MAF car. It can be fixed with shaft bushings and a reamer.
These cars aren't the smoothest running machines.
sorry I just gotta...Sounds like the throttle shaft hole is worn a bit. Not a massive deal unless your a MAF car. It can be fixed with shaft bushings and a reamer.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
or you might be hearing the iac, the iac gets vacuum through the plenum and fresh air through a hole in the center of the throttle body.
Engine: 5.7 L98
thats what it is, put a stethascope on it. thanks
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
