Installing this cam in my car, will it work?
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I found this cam on ebay and it is in my price range and would like to buy it. (http://www.ebay.com/itm/Chevy-350-5-...ht_1987wt_1270)
It would be going in a 89 Camaro MAF TPI 305 LB9 engine. My heads have only 60,000 miles on them, would I need new valve springs? Let me know guys
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Installing this cam in my car, will it work?
I also want to be able to keep my stock 89 305 AUTO PROM
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Yes that cam will work with your stock springs, but I would replace them.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
That a little much for that cam, just run a lt1 cam.
Car: 1990 Camaro RS
Axle/Gears: Posi
those arent the stock specs of an lt1 cam? I thought they were, and what kind of numbers will I see with the lt1 cam? compared to the little tiny cam in there now
Engine: Lb9
Transmission: M20
Lt1 cam specs
Engine Valve Lift @ .050"(1.3mm) Specification Engine Lobe Lift @ .050"(1.3mm) Specification
LT1 Intake .447"(11.35mm) LT1 Intake .298"(7.57mm)
Exhaust .459"(11.66mm) Exhaust .306"(7.77mm)
LT1 Intake 205 deg. LT1 117 deg.
Engine: Lb9
Transmission: M20
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
the cam you want to buy for $180
207 /214 .410 /.427 117
has less lift than the stock 88/89 305 cam in your engine at present
207/213 .415/ .430 117
Just buy a take out LT1 cam ( with more lift than either of the above cams ) and don't pay more than $50
https://www.thirdgen.org/forums/engi...-cam-sale.html
https://www.thirdgen.org/forums/engi...stock-lt1.html
https://www.thirdgen.org/forums/engi...1-lt1-cam.html
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
