fuel pressure zero right after turning ignition off
Car: 1989 IROC-Z
I have a 89 IROC-Z with a 350 TPI. When I turn on the key, you can hear the fuel pump running, then turns off. It has pressure then. After I turn the key off and check the pressure I show no pressure at all. My question is: Is this correct or should it hold pressure? Thank You and God Bless US All...John
Car: 1989 IROC-Z
Re: fuel pressure zero right after turning ignition off
If it should hold pressure. What would be the fix? New fuel pressure regulator? The fuel pump was changed about 9 months ago. Thank You all in advance and God Bless US All....John
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Could be leaking FPR, leaking injectors, leaking pump check valve, or an external leak.
Car: 1989 IROC-Z
Well it looks like I have a bunch of troubleshooting to do.. Just where to start first. I don't believe there is an external leak in the system. Underside of car is dry everywhere. Fuel pressure regulator first or injectors? How would you check the Fuel injectors? Thank You and God Bless US All....John
Engine: 4++,350 & 305 CIs
It should holp psi but if the car gets full fuel psi and starts right up, you really don't have a problem.. Mines been that way 4 20 years.
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
