EGR vacuum line question
Old Jun 11, 2012 | 08:04 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Hi there. I have my EGR disabled in my tune, but I need to keep the valve for appearance reasons. On the EGR solinoid, there are 2 vacuum lines that run into it. One comes off the egr valve itself, the other runs to the evap canister. Can i plug the vacuum ports on the solinoid, egr valve and evap canister and not toss a code? I want to remove the bracket the solinoid attaches to, but just let sit there.
Kevin
Old Jun 12, 2012 | 01:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: EGR vacuum line question
If disabled in the tune ,the ECM will never try to operate the valve .
Consequentially; if not trying to operate the EGR , ECM will never throw a code from the EGR not operating
So you can remove/ plug what ever you like; vac or electrical
Evap canister is seperate system ; no codes from removal but require vac to operate if left in place
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
camaroken83
Aug 10, 2015 11:35 AM
