Am I retarded or....
Old Jun 9, 2012 | 05:52 PM
Kevin Lee 487's Avatar
Car: 1999 Trans Am Ram Air
is it damn near impossible to remove the # 2, 4 and 6 plugs on an L98?
I can barely fit my hand in to touch them, let alone fit a socket in there to remove them. I even tried saying screw it and removing them from the top instead of underneath like all # 1,3,5 and 7 plugs on the driver side. I'm really sweating this because all 5 of the plugs I was able to remove looked in pretty rough shape. ( The #7 & 8 plug wires were so tight that I had to twist the boot to remove the plug from the engine and then pull the boot off afterward )
I also don't want to just waste 3 AC/Delco plugs or damage the damn $90 MSD wires I got ( curse you stock exhaust manifold requiring a long boot )
I don't know if the Camaro is any different, but this seems like I'm missing something simple.
Old Jun 9, 2012 | 05:56 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: Am I retarded or....
No it is a big pain! Find a real skinny person that is strong with long arms to help you. haha
Old Jun 9, 2012 | 06:56 PM
I've employed the help of my 5'4'' friend who probably weighs like 110lbs.
Me being 6'1''-2'' ish and 180lbs is obviously too big lmao.
Thanks for the tip.
Old Jun 10, 2012 | 02:02 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
A baboon? But the answer to your subject line question....????
Old Jun 10, 2012 | 02:24 AM
Twin_Turbo's Avatar
those are easily removed from the bottom
Old Jun 10, 2012 | 04:04 AM
inkedbass's Avatar
Thanks for the tip.
I feel your pain. Only 5'10" but 215lbs so its not easy for me either.
J
Old Jun 10, 2012 | 07:34 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
I modified a socket to make the task easier. Or you can buy one already made for you.
http://www.jegs.com/p/SLP/SLP-Spark-...64116/10002/-1
Old Jun 10, 2012 | 11:58 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
its best to remove plugs on these cars from the bottom.i use a wrench /plug socket combo, go slow and use antisieze.and if you think you hate doing it now,thank god you dont have headers!!
Old Jun 10, 2012 | 12:44 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
+1
I bought one of these to use with my headers. Makes life a lot easier.
Old Jun 10, 2012 | 01:04 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
^agreed. I modified my own and it made worlds of difference
Old Jun 10, 2012 | 01:35 PM
Rickman2k's Avatar
their all easy on my trucks TPI motor with Hooker headers
Old Jun 12, 2012 | 07:56 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Old Jun 12, 2012 | 08:15 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i had prolems on my camaro so i decided that was a great time to put the headers i had in the basement on .lol
Old Jun 12, 2012 | 09:18 AM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Headers make it ten times easier. They do on my TPI 350 anyway. I could do plugs in thirty mins with a beer.
Old Jun 12, 2012 | 09:20 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i agree i have one thats still a bitch but after i delete the ac box that will be taken care of to
383backinblack
Sep 25, 2015 11:31 AM
ericjon262
Sep 11, 2015 06:07 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Ken88GTA
Jun 12, 2001 01:57 AM
crazeinc
Dec 6, 2000 01:00 PM
